BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 Mechanical Oil Pressure Gauge NEW TOPIC NEW POLL POST REPLY
rtbain
old, fat and slow
posted June 28, 2009 07:22 AM
Anyone know where to source a mechanical oil pressure gauge or at least the fittings to adapt to the stock oil pressure sending unit opening?
Randy
  Ignore this member    Click here to visit rtbain's homepage.
Ozonkiller
posted June 28, 2009 08:59 AM
Jegs?
pissear
Professional Cockis Slap Peer
posted June 28, 2009 07:46 PM
What is wrong with a pipe fitting with a T tied to it. You reinstall the oil fitting so the dash light is off. You then run that clear oil line that comes with the unit, run it up to the dash or handlebar area or wherever you feel comfortable reading the gauge.
I am not sure of the oil pressure switch being standard pipe fitting thread pitch? Sure looks like you can make that dual adapter work is Home Depot and Jegs are waiting.
Compton
posted June 28, 2009 07:51 PM
i did this on mine, just used a 1/8th T. put my oil pressure sender on one side, the stock switch on the other and into the pan on the other.
you can't use the 1/4npt plug on the side, anything you put there will hit the body work.
b.w.
rtbain
old, fat and slow
posted June 29, 2009 05:16 AM
Found the fitting!
JIS to 1/8th NPT adapter
www.cycle-logicmotorsports.com
Link: http://www.cycle-logicmotorsports.com/index.php?main_page=product_info&products_id=53
Randy
0.24284219741821 seconds processing time
