BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy fuel system NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted June 25, 2009 06:30 AM
Muzzy fuel system
Will I need to get the bikr retuned when I install it,does it have more fuel pressure or will it be okay as is when I install it,already had chris jones tune the bike with the setup that I have now,muzzy sidewinder,bmc race filter,crank breather mod,tre,secondary butterflies gone,programmer with hub,17/43 gearing.Have a dyno tune nitrous kit that I bought for it also but putting that on next month and taking back to chris for a retune.
Just another foeteen!!!!!
1badvespa1400cc
power junkie
posted June 25, 2009 09:40 AM
Can anyone help on this subject.?
NINJA12
posted June 25, 2009 11:18 AM
Probably should give Chris a call,
He would know.
1badvespa1400cc
power junkie
posted June 25, 2009 12:26 PM
Yeah that would be a good idea!!!
bigwil
06 zx 14 turbo stage 3
posted June 25, 2009 02:02 PM
the muzzy pump should run fine w/ that set up but i would make a diff. map for nos so you can add more fuel
did you ship that arm havent got yet
bigwil// going fast aint easy so turbo it
posted June 25, 2009 06:17 PM        Edited By: dubious on 26 Jun 2009 02:20
set your fuel pressure regulator to stock pressure specs... (38 psi i think?)-haven't got my manual on me... but ,match the factory specs, and the tune will be the same.
The injector duration has not changed, unless you changed the map, so the only thing different would be the pressure .
when Chris retunes for NOS he might bump the fuel pressure up but only if you are running a BIG shot likely, otherwise he would just get your Nitrous mapped out
Chris is a great guy to deal with and knows his stuff for sure!
How much N02 you plan to run?
1badvespa1400cc
power junkie
posted June 26, 2009 06:37 AM
The muzzy kit doesnt come with an adjustable regulator it looks like one you would buy for a stock setup on a car,maybe it is preset from muzzy,I dont know.If you go on schnitz you can see it in there.Oh and I am running a 40 shot.
posted June 26, 2009 07:55 AM
Strange,
Mine came with a Turbosmart adjustable fuel pressure regulator...
Was adjustable, and could be hooked up for boost reference too, or not.
hate to say it but, for a 40 shot the stock system is sufficient.
1badvespa1400cc
power junkie
posted June 26, 2009 10:17 AM
Planning on boosting it later so I was just getting this out of the way.
1badvespa1400cc
power junkie
posted June 26, 2009 10:19 AM
Yep went out today and I have a tracking number for you,call me when you get a minute.
0.24262285232544 seconds processing time
