BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy Fan NEW TOPIC NEW POLL POST REPLY
epd345
posted June 24, 2009 08:19 PM
Muzzy Fan
Does replacing the stock fan with the metal muzzy fan really make any difference in keeping the bike cooler?
AcadianaZX
Advertiser
posted June 24, 2009 10:51 PM
I put it on my bike and It does move more volume of air, but I put the cycle logic coolant at the same time. So I'm not sure what was the contributing factor to 1 less bar on the temp.
James
dcjens
Wet side of Washington
posted June 24, 2009 11:00 PM
I added a stock second fan which works well and its as quiet as the single stocker BUT I had great results switching to the ZX10 front fender! It dropped my heat down a notch on the gauge and I don't hear my fan(s) kick on but at a stop or slow moving. Try that first, then the coolant upgrade, then mess with the fan(s)
Black 06
FasterThanStink
posted June 25, 2009 04:29 PM
I dropped the heat down a bar by changing oil to Motul 300V. Expensive but helped with the cooling and made clutchless shifts effortless.
That's what gets you.
14nooby
posted June 25, 2009 05:07 PM
No,
I have riden 06' with it and it heats up just as quick as my 09 with the stock fan. I am sure a few on here will disagree but don't wast your money.
AcadianaZX
Advertiser
posted June 25, 2009 11:09 PM
Amsoil has the best cooling and more of oils in API standards testing. Log on to lubedealer.com/tjsynthetics and get a free white paper showing the results. In 2000 when I first used it in my Harley I was skeptical an did my own test around town in traffic with a temp gun and found it to run 15 degs. cooler that the Harley syn, Along with smoother clutchless shifting. Hope this helps your cooling issues. I'm sure any synthetic motorcycle oil would help the ZX14 a little. That is good advice on cost savings.
James
pazx14rider
posted June 26, 2009 05:51 AM
Dont waste your money. I put it on it rubbed had to bend it . Noise went away then came back rubbing again. I took it off and threw it in the garage. Best result I had is a 1 bar decrease with Engine Ice Coolant.
iflyems
posted June 26, 2009 07:13 AM
No,
+1 No. Waste of money
epd345
posted June 26, 2009 01:07 PM
Douglas Home
posted June 26, 2009 03:07 PM
I've put in an over ride switch to manualy turn on the stock fan when in slow traffic or on the return road works great ! cheap too!
Doug Mackay Australia
JDC
posted June 27, 2009 05:40 AM
I put he Muzzy fan on and I beliweve it is helpful.
0.38912391662598 seconds processing time
