BIKELAND > FORUMS > ZX-14.com > Thread: Dyno Jet auto tune testing ... NEW TOPIC NEW POLL POST REPLY
posted June 24, 2009 08:08 PM        Edited By: smokinZX14 on 25 Jun 2009 04:30
Dyno Jet Auto Tune testing, If you want to call it Auto tune because it's really not ..
We started off the night with 4 base line runs on Brocks race map while the auto was in learn mode .....The Auto Tune made some changes in the lower RPMs but made only some very small changes in the upper RPMs ... The Auto tune will not make the changes to Brocks map untill you tell to.. So we sent the Auto Tune trim numbers to Brocks map , the auto tune over writes the changes onto Brocks map .. I had a feeling that we would not see any changes in ET or MPH because the auto tune numbers were so close to Brocks numbers , meaning the auto tune found Brocks map to be almost spot on the mid and upper RPMs .. Most of the auto trim were zeros meaning no change needed ....Like i said it did remove some fuel down low .. 5% to 10 % throttle @ 3000 and below ... well i'm never in that range going down the drag strip .. I stage at 5000 and never see anything below that , within a few feet i'm at 100% throttle ...So the numbers the auto tune added do little or nothing at the drag strip ...The may help riding on the street for everyday riding but not the track .. So in a nut shell we saw no gains in MPH or ET , if anything we saw just a bit of loss in MPH and ET ...Later in the night the track started going away and that may have caused the tiny tiny bit of ET and MPH loss and not the auto tune ..
Remember this is an 1/8 mile track and i feel testing in the 1/4 mile may show loss or gains better than the 1/8 mile .. So thursday night we are heading down to the 1/4 mile and make 4 runs on the Brocks race map and then change to the new auto tune map and see if it makes any difference ... I have will the auto tune in learn mode and see if it asked for any changes in the base map , if it does i will install them and make some more passes and see what it does .. Like i said this auto tune is far from being an auto tunning ...
I will also be testing both maps on the dyno when i have the dyno up and running ..
At this point i wish i had not spent the money on the auto tune, that might change with more testing .. I'm a firm believer in Brocks maps and the auto tune is proving my belief ..
I would say for most guys just load a brocks map and ever look back .. There are some guys like me that allway look for that last little gain power and with this unit you may find it if you are willing to put the time in at the track and the dyno ..
More on this after Thrusday night testing ..
Smokin ...
posted June 24, 2009 09:55 PM
Sounds likethe bazzaz.
Had to manualy update the map with the suggested changes.
Might be good for the guys who ride in varying elevations and temps though I would think?
starchild
posted June 25, 2009 02:48 AM
thanks smoke been debating on whether to buy the auto tune or stick with the data logger. not having any success with it starts to record then cuts off.cant figure it out.
jay
posted June 25, 2009 06:35 AM
Yes i think it might be good for that and save some redyno time ... What they really need is a true 02 closed loop system ...
WARBIRD
posted June 25, 2009 06:56 AM
+1 on the closed loop...............but like you said, Brock has done a fine job on his maps............a PCIII and his map is quick, accurate and simple......
I'd Rather Be Roadracing.
1badvespa1400cc
power junkie
posted June 25, 2009 07:35 AM
Good luck at the track hope to see some good numbers!
Just another foeteen!!!!!
JR
drag racing
posted June 25, 2009 08:31 AM
good to know.
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
bruno nadeau
posted June 25, 2009 09:05 AM
take a look at motty afr tuner it is a closed loop with WB sensor and a dataloger .i can datalog afr,engine temp,laps,rpm,speed,map 1 or 2 .tps,target afr,can switch between 2 maps.datalog memory is 3.5 hours,you can use NOS.i use it for 10000 KM on my 06 14 it worked very well.i will instal it on my 09SE zx14 as soon i will get my plug and play harnes maybe today or tomorow.it is very easy to use =built your target afr map load it to the afr tuner ride the bike and the afr map built itselft .EX it take me 4 run at full throttle in gear 4 to built a steady 12,8 afr map from 5000 to 11000 rpm(you can see the progres in the log).the fuel map is like a power commander with many more cells.www.afrtuner.com
bruno nadeau
posted June 25, 2009 09:10 AM
Lee, I would be interested to see what it comes up with if you start with a zero map. And how long it takes to get it tuned...
posted June 25, 2009 07:06 PM
I'll be testing on the dyno Shane and will test that for you ...It took 4 passes at the track so maybe 3 or 4 dyno pulls ? maybe ?
posted June 25, 2009 07:18 PM
Update
All hell let go tonight ... First off i had a fender bender on the way to the track .. I rear ended a car at about 5 mph .... The gal slammed on the brakes and i just couldn't get stopped in time ... If i had 3 more feet i would have not hit her ...I'm sure she will sue me ( they all do ) . No cops called , so no ticket for me ...
I got to the track ok because my truck had no damage ...The track was so bad all did is spin every gear ..Everbody was spinning and the track crew did nothing to fix the problem ... Everybody was pissed off.. I gave up after 4 trys and loaded up my bike and just watched everybody spin down the track .. Even the front wheel cheap ass 95 HP Hondas were spinnig third and fourth gears ....It was just a big waste of time and money ...I hope to have the bike on the dyno this weekend and get some numbers with the autotune .... Sorry guys..
posted June 25, 2009 07:26 PM
Guys I did get some first hand info on the Bazza tunner ...Unlike the autotune where i can set target a/f ratios in any cell i please the Bazza unit only lets you have one ratio in the hole map .You pick 13.1 and that what you get for the hole map .The autotune you can have 13.7 in one cell and 13.0 in another . The guy that was using the Bazza said he wished he had got the Autotune unit ...He said you could write over and change a number but it's a pain in the ass and doesn't work all that well ..
posted June 25, 2009 09:13 PM        Edited By: dubious on 26 Jun 2009 05:28
how would the average guy who doesn't own a dyno know what AFR makes the best HP, or throttle response, better yet 1/4 mile time for his specific set up though?
I would think they still need to take the bike to a dyno and map for HP, then they would have the "best HP" AFR plotted, and use that as a guidline for each cell target?
Kinda defeats the purpose, with exceptions to varying elevation and temps though?
I set the 08 zx10 up for street and power with a bazzaz, and basically made a map for 13.2:1 at anything over 50% throttle, and once got that dialed, 14.5:1 for fuel economy in all cells 50% or less TPS. I picked 13.2 from the info Brock was kind enough to provide, as he did not have Bazzaz maps for the alien head, but did have a PC3 map and dyno graph with the AFR's on it to use as a guidline.
I will say, it wanted BIG changes in fuel for a map made at 60F versus 85F...
And the little bastard was stinking fast... I wish I could have rode it and uncorked version of my zx14 back to back for a true comparison, but it was really a spooky little bike once it was uncorked... in fact for the 1st time in a long time a bike scared me a little, being so wheelie prone and unstable compared to the zx14. I never had to worry about how the zx14 handled, it was predictable, but the 08-zx10 uncorked wanted to stand up and wag its head at speeds over 150 mph, with the stock ohlins damper cranked to FULL stiff.
I didin't feel that way about the zx10 when it was stock, but sure changed my opinion uncorked.
Also, at more than one point the stock zx10 injectors (bazzaz drives all 8, not 4 like the DJ) were maxed out in duty cycle with just the alien head and K&N looking for 13:1 AFR!
LOL the DJ can control fine tuning and drivability better, but can not drive as much fuel as the bazzaz due to the 4 injector control, instead of 8, so the model of the bike is something to consider as well.
Each has its advantage and pitfalls. For bikes with 8 injectors the Bazzaz is the cheaper route, but at the same time the DJ has 250 rpm map spread, wheras the Bazzaz is 500 rpm spread.
After learning more about the new PC5, i would prefer that unit, even though the options add up, it is expandable, wheras the bazzaz, you buy it with the options it has, and thats what your stuck with. And the 500 rpm spread with the bazzaz was difficult to tune at low rpm, and low TPS.
The Motty is a closed loop, and they have been using them on GSXR1000 since 2005.
The gentleman making this system has been building them on subaru's prior, and seems very intelligent.
I do not know anything about the unit as far as how fine or course the cells are, or how the software is to use, etc...
The biggest down fall is you had to splice into your stock harness before, and as Bruno stated it sounds like that is corrected too.
again, can each cell have its own target AFR, and how do you determine what the "BEST" afr is for each cell without a dyno?
Realisticaly I don't think anyone is going to see any improvement with a map so fine tuned it has a specific AFR target for each cell, the bike revs through them so fast, that 3 or 4 ideal target ranges over the entire map will likely provide the same end result in ET and MPH.
I am willing to bet Smokin and his new Dynojet and love of the race will either prove or disprove my theory though!
I am not picking a debate, just pointing out some prespectives, and my own personal experiences so people can make their own decisions from our experiences with each unit.
As I said, after learning everything I have lately , I would still prefer the Power Commander with the aftermarket support, and 250 rpm cell range.
I am dying to find out if the uncorked 09 zx14 really is any faster as the similar configured uncorked 06zx14 you owned though!
posted June 25, 2009 09:48 PM
how would the average guy who doesn't own a dyno know what AFR makes the best HP, or throttle response, better yet 1/4 mile time though?
I set the 08 zx10 up for street and power with a bazzaz, and basically made a map for 13.2:1 at anything over 50% throttle, and once got that dialed, 14.5:1 for fuel economy in all cells 50% or less TPS. I picked 13.2 from the info Brock was kind enough to provide, as he did not have Bazzaz maps, but did have a PC3 map and dyno graph with the AFR's on it to use as a guidline.
And the little bastard was stinking fast... I wish I could have rode it and uncorked version of my zx14 back to back for a true comparison, but it was really a spooky little bike once it was uncorked... in fact for the 1st time in a long time it scared me a little, being so wheelie prone and unstable compared to the zx14. I never had to worry about how the zx14 handled, it was predictable, but the 08-zx10 uncorked wanted to stand up and wag its head at speeds over 150 mph, with the stock ohlins damper cranked to FULL stiff.
I am not picking a debate, just pointing out some prespectives, and my own personal experiences so people can make their own informed decisions.
That is how i see it also .... You really need a dyno to know your best target a/f ratio ..Like i said i used Brocks brocks map .... If you allready have the best the autotune will be worthless ... I can see it being a help if you race at 5000 feet and then go to sea level or summer to winter temp changes ... You would simply use the autotune to make corrections ....There are more tricks and skills other than just setting a map to 13.0 and hope for the best , good tunners know that and you can see that in their maps ..
So autotune or not you still need a great base map to work off of ... The auto tune will build you a base map from a zero map but you still need to know what the best target AFR is and that will be different from bike to bike .. I also think riding styles or type of riding come into play also.... I look at it this way , Auto tune is a tool much like a screw driver or any other tool in your tool box , if you don't know how to use it it's of no value...
posted June 25, 2009 09:55 PM
edited it while you were responding...LOL
Bently
2012 14r In Blue and no Mods!
posted June 26, 2009 03:04 AM
We are tuning an 08 busa with a bazzaz and it's simple and works great. with an off the shelf Hindle pipe for 600 bucks new and the bazzaz the bike has ran faster and quicker then a Brocks hindle and map with same rider not enough faster to worry about but we also tuned it for nos with the bazzaz which was nice
posted June 26, 2009 08:01 AM
E1000
posted July 09, 2009 04:31 AM
when you mention brocks map which map are guys referencing, which track map or is it the maxton?
also what fuel for NOS is better C16 or Q16 at what afr?
thanks
1st GEN ZX14
few bolt ons
gilberjj
Friend of Fast
posted July 17, 2009 09:42 AM
any updates?
posted July 17, 2009 07:23 PM
any updates?
Only thing i tried was to fatten the map 3% but the dyno showed a lost of 2 hp .. I reloaded the brocks map and ran it last night on the dyno and got back the 2 hp 177.62 ... I raced it tonight and ran a 5.69 @ 124.27 ... Brocks map seem to be dead on .. Guess i'll have to look elsewhere for more power ...
The map i'm using for those who don't know is Brocks street and track map , flys out for pump gas .. This map is for the new PCV power commander and not the older PC3 ..
posted July 17, 2009 07:58 PM
Here is what i think so far on the PVC Autotune ... Buy the new PCV and skip the Auto tune part .. If you have a good map like Brocks the Autotune is going to do nothing for you ... 99% of the zx14s owners will never need or use the Autotune ... The Autotune may help refine your map but the change is so small you will never see or feel it ..If you like to tinker you will have fun with it trying different things .. One place the Autotune may come in handy is you can map every gear ... Lets say you map the lower gears where ram air doesn't come into play you can keep the lower gears lean ( 1, 2 ,3 ) For the top end of the track ( 4, 5, 6 ) gears you can have the map a bit richer for the ram air ... I have not tried this yet but it looks like it may be helpfull ...It may be a big help in LSR like Maxton or the TX mile where ram air speeds are so high..
The PCV its self is very nice and has a lot of things the older PC3 doesn't have .. So by all means update to the new PCV if you can..
Smokin ...
posted July 18, 2009 03:30 AM
I am curious about mapping the gears. How is the unit detecting which gear you are in?
I figured it should be as simple as the value from the gear position sensor. But somehow Kawasaki didn't think that was good enough for the gear indicating display (it gets confused with a gearing change). So, I am curious as to how it will work with the PCV.
bruno nadeau
posted July 18, 2009 04:27 AM
my 06 gear display gets confused but my 09 work just fine.i dont know for the pc5 but the motty afr tuner on a bike with no TPS sensor or a confused TPS like my 06 use a different firmware that calculate speed versus RPM to calculate the gear position.
bruno nadeau
0.22057390213013 seconds processing time
