BIKELAND > FORUMS > ZX-14.com > Thread: i found out what happens when boost regulator hose falls off NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted June 23, 2009 06:55 AM        Edited By: 1badzx12r on 23 Jun 2009 14:57
zx14 stumbs like a mofo for a second as it charges to full boost 25lbs .. i can't believe its no harm done .. but motor is fine ..i guess i'm 1 lucky mofo ..
in short went for my normal morning ride to have coffee .. when getting on interstate i WOT it and it stumbs and then charges forward ..wheeling in 5th gear .. i look down and see a/f and boost gauge about the time i shift 6th and go fluck 25lbs of boost and 14.6 a/f ..
JDC
posted June 23, 2009 07:25 AM        Edited By: JDC on 23 Jun 2009 15:25
Wild.
Glad no harm to you bike. Wheeling in 5th!
Superman T
posted June 23, 2009 07:29 AM
Hope u get it figured out
zxbob
posted June 23, 2009 07:55 AM
Your lucky ..... go buy a lotto ticket !
Bob
posted June 23, 2009 07:57 AM
What pistons do you have in that thing??
1badzx12r
posted June 23, 2009 08:53 AM        Edited By: zxbob on 23 Jun 2009 22:42
stock pistons ..
lottery ticket was 1st thing i did bob ..
I thought you put pisstons in that motor ?
Bob
1badzx12r
posted June 23, 2009 08:59 AM        Edited By: 1badzx12r on 23 Jun 2009 17:01
Wild.
Wheeling in 5th!
thats when i knew something was wrong ..
fuel stumbles i get occasionally . but 1st time to wheelie 5th .. but it regularly power wheelies or float the front tire in 4th ..17/45 gearing and michelin power race tire
Compton
posted June 23, 2009 11:01 AM
im surprised the rings arent in 1000 pieces.
b.w.
1badzx12r
posted June 23, 2009 11:44 AM
i had done a compression test last tune up with spark plug replacement .. had 195lbs straight across with 10,000 miles and 400 drag passes with boost range as high as 14lbs ..
maybe i should do another before next tune up .. but i have no blow by coming from breather ..
iflyems
posted June 23, 2009 11:53 AM
I would be worried more about the rod bearings you just crushed/made square. The least I would do is drain the oil and cut open the oil filter looking for "sparklies". There's a real good chance replacing rod bearings is in your near future.
kaw-rick
posted June 23, 2009 11:57 AM
reminds me of the time my fuel pump quit working on my nitrous. instant 1/4 mile wheelie thru the traps. took me a sec to figure out what was going on.
Douglas Home
posted June 23, 2009 12:26 PM
Nitrous and no fuel , with combustion?
Doug Mackay Australia
He has a wet system...
1badzx12r
posted June 23, 2009 12:43 PM        Edited By: 1badzx12r on 23 Jun 2009 20:44
I would be worried more about the rod bearings you just crushed/made square. The least I would do is drain the oil and cut open the oil filter looking for "sparklies". .
sound advice.. but i hear no knock and and i'd just changed oil and filter last weekend dang-it
but every oil change i've had aluminium sparkies in my drain pan .. no copper sparkies tho .. what do you use to cut the filter with i screw that up every time .. .. i also done went for several runs already today @10lbs and WOT and no issues .. i think that the way i've dog on it today after fixing hose something would show .. and i'm 1 them guys that if it ain't broken don't mess with it ..
iflyems
posted June 23, 2009 01:45 PM
You won't hear the rod knock til it's too late. Use a hack saw to cut open the filter. Your looking for Babbet bearing pieces. Should be pretty easy to see, just unwind the filter past the filing from the saw. As far as aluminum shaving, dunno what's up with that.
1badzx12r
posted June 23, 2009 02:18 PM
i think all of them have aluminum sparkies .. hacksaw is what i've used ..but you get so many metal shavings from cutting the filter .. i've got a pipe cutter maybe i'll try that next time..
remember back in the day the magnet drain plugs and all the metal that would be on them ..
posted June 23, 2009 08:36 PM        Edited By: dubious on 24 Jun 2009 04:36
Man , on pump fuel?
Thats gotta be bad.
Hopefully you caught it quick enough.
Have you checked the plugs?
kaw-rick
posted June 24, 2009 03:09 AM
Yeh everything was cool. Happened a while back. Was like riding a bull. Was making some power for sure.
1badzx12r
posted June 24, 2009 03:33 AM        Edited By: 1badzx12r on 24 Jun 2009 11:34
no dub ..i've always got avgas in it .. i haven't done nothing but just ride the bike ... i'm getting ready for my coffee trip again today .. if it breaks .. i've got another motor .. but if it doen't break i'll give it a good checking next service ..
reevesmreeves
posted June 24, 2009 04:36 AM
suzuki still uses them. all the busa owners have been asking me why kawi doesn't?
06 red 14
06 se 636
posted June 24, 2009 06:24 AM
You'll be fine on avgas for the every odd occaision... good insurance.
I will have to look into the costs of it here
1badzx12r
posted June 24, 2009 07:40 AM        Edited By: 1badzx12r on 24 Jun 2009 15:42
bike ran fine did a 100 mile ride and several WOT roll-ons ..no issues.. thats why i use the avgas Dub even if i mix it 50/50 with pump i feel safer .. And i credit avgas with keeping my bike running even with problems i had with my shifter.. i had mis-shifting on the track at least 50 times until i got problem solved .. tire spins also .. i pay 3.75 a gallon it was 3.15 a gallon until recently here
Reeves i know that aftermarket sells them ..but i've just haven't purchased 1 yet for my bike.. i think mother kawi don't want us to see all the metal on the drain plug
posted June 24, 2009 07:43 AM
when you say mis-shift...did you ever have it pop out of gear? I only had that happen once, but I didn't like it...(popped down 3-->2 under power from a bad shift).
1badzx12r
posted June 24, 2009 07:48 AM        Edited By: 1badzx12r on 24 Jun 2009 15:49
NO i never had it jump out of gear .. What i installed was an MPS auto-shifter with kill and wanted auto-shifting .. but problem was if motor unloads off of tranny ( like tire spin or clutch) or not enough delay time it won't go into the next gear ..it will stay in the current gear it spun in and hit the rev-limitor ..
bigwil
06 zx 14 turbo stage 3
posted June 24, 2009 08:00 AM
so now you felt that baby come alive so when are you building that moter so 25lbs is evrey day
ahh happiness is making boost !!!
bigwil// going fast aint easy so turbo it
0.22664403915405 seconds processing time
