rtbain
old, fat and slow
posted June 19, 2009 02:34 AM
PCIII question
Does the PCIII modify ECU output or use it for a trigger? The reason I ask is my '07 ZX14 has a good amount of onboard sensors that monitor RAD (relative air density) as well as intake pressure.
If the PCIII uses the ECU as a trigger the data from these sensors will be irrelevant. If it modifies injector pulse width then the sensors will still be in use.
Randy
