BIKELAND > FORUMS > ZX-14.com > Thread: steering dampener NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted June 12, 2009 05:21 PM
steering dampener
I've got an ohlins dampener with a Brocks mounting kit , the bolt at the front of the tank into the frame keeps loosening . I dont want to locktite it .
Anyone else had this problem / what was the best solution???
It is a great product and I'm happy with it other than this problem.
Doug Mackay Australia
zxbob
posted June 12, 2009 05:36 PM
There's one on my (old) bike ... 2+ years, no problem.
Bob
masszx14
A mind beside itself!
posted June 12, 2009 06:25 PM
Locktite it.... blue off course.
That's what I do with mine with zero issues.
universal@mind
TampaSmitty
posted June 12, 2009 07:03 PM
i dont have experience with you prob, but just remember there was locktite on ur flies lol.
like nike just do it.
whats the worst a pain in the ass to remove?lol
06 1st gen zx14,muzzy full exhaust, pc3,no flies tuned at 180rwhp and sold after 15500miles with leaky valve cover bolts and a shreaded back tire.
now 07 ,corbin hardbags
pc3, muzzy m14 ,flies out..
posted June 12, 2009 07:54 PM
Use a few drops of the blue medium sparingly and you can't go wrong.
LLcooljebb
Upgrade I Must
posted June 12, 2009 08:08 PM
Put a Ohlins/Brocks on mine last month. Thanks for the heads-up...I'll keep a close watch on that bolt.
"no time to be void or save up on life
you got to spend it all.."
masszx14
posted June 13, 2009 01:45 PM
Blue or red Locktite on everything that the SM calls for!
There are no ill effects to use the blue on any bolts
universal@mind
Douglas Home
posted July 04, 2009 01:24 AM
Today at the track the bolt at the frame snapped . When I got to the pits to take it off , the brass cylinder that goes down the fork tube was gone .
I will check it out in the daylight tomorow and give you more info.
Anyone else had this happen ?
I will see if I can use easy outs to remove the snapped bolt and see if Brocks
will sell just the bracket for the centre mount, I still have faith in him and his product .
posted July 04, 2009 03:05 AM
Damn doug, your not having the best of luck with that dampner are ya?
Douglas Home
posted July 04, 2009 05:07 AM
umm nope !!!!!
Douglas Home
posted July 05, 2009 02:14 AM
OK this is what I think has happened , the bolt with the brass bush has snapped dropping the brass bush down the headstem tube and out the other end (lost).
After this I presume is when I noticed the bolt into the frame coming loose . So if this happens to you take it off and inspect the bush .
So then I think the extra pressure has loosened the bolt that goes into the frame !
Hopefully two easyout extractions of the two snapped studs and if I can purchase just the brass section all will be well at minimul cost.
Learn from my mistake if this bolt loosens inspect the brass bush!!!
Any one heard of this happening before?
Douglas Home
posted July 05, 2009 03:44 AM
You Americans are always bloody sleeping when I need an answer!!!
Douglas Home
posted July 06, 2009 07:00 AM
Bump. So its just me , makesme feel special!
So no one's heard of this happening before???????
posted July 06, 2009 08:18 AM
I run ths scotts radial damper sorry- I can't help
Douglas Home
posted July 08, 2009 11:19 AM
Well it is true what you all say about Brock , he is sending replacement parts!
Not many bussiness men this reputable thesedays!
0.21063113212585 seconds processing time
