BIKELAND > FORUMS > ZX-14.com > Thread: How to Make Two Brothers Pipes Louder?? NEW TOPIC NEW POLL POST REPLY
BigBadZX14
posted June 08, 2009 04:44 AM
I have Two Brothers Pipes on my ZX14. How can I make them a little more louder or throatier?? Can I remove some packing, or baffels?? And how?? Any thoughts??
08' ZX14 Midnight Saphire Blue, Two Brothers Slip ons, PMR Tether Cut off Switch, Fender Eliminator Kit,
LAB3
posted June 08, 2009 04:57 AM
My advise is Not to try removing the packing. Major PIA to do this with out a jig fixture
to hold the muffler so you do not crush the inside core. Just keep riding, the packing
will burn out in about 5000 miles ro less, depends on your right hand :-)
ncognegro
posted June 09, 2009 12:20 PM
I have removed packing for my mufflers and for friends before.I live in the stix and no one cares about loud pipes where I am at.Plus I like my pipes loud cuz most cars seem to be able to hear loud pipes b4 they see ya.Go figure.
All I do is drill out the rivets in the rear of the pipe.i then remove the baffle and packing.It's easier to get the packing out without the baffle. I replace the baffle and re rivet the pipe.Pretty easy and louder to boot.Some pipes that are a real tight fit need alot more pulling on the end cap to get them to separate other than that it's easy.
LAB3
posted June 09, 2009 01:30 PM
You have been lucky. Some pipe makers end caps are spot welded to the perforated core inside that the
packing wraps around. When you try to use a soft mallet and bump out the core they get stuck and you bend the inner core so now you have to buy a replacement end cap core assembly. It depends who has made the silencer. And sometimes reriveting back in the orginal hoes the rivet come loose after some time and miles and the hole you drilled thru is no a little larger dia. so the rivet is not as tight. I was Sales Manager/Tech Support at
D&D Exhaust back in the 90's and have seen some really bad examples of this going
wrong. On a carbon fiber sleve it is neally easy to ruin a silencer. And Yes a loud exhaust is a Great Horn.
Bawls
re-learning to ride
posted June 09, 2009 04:52 PM
if he has the 08 then doesn't it have a cat in the headpipe as well that he can bust out and get some more flow through? I know that when i put my pipe on a guy at bike night was quick to snag my 07 headpipe for his 08.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
SticknMove
posted June 10, 2009 09:51 AM
By a Brock System and throw your Two Brothers in the trash, that's how you make them louder.
Da New King
Red1
posted June 10, 2009 04:57 PM
+1 ,
You can remove the baffle if you want it even louder!!!
Red12/Blue14
Sticks_n_Stones
posted June 10, 2009 05:04 PM
If you can see gold colored inserts at the end (they will be black if they were in there very long, just wipe the soot off), then they are removeable and will significantly increase your sound level. I bought my 'baffles' (the gold inserts) to quite mine down, they are worth $50 so dont throw them away. Here is a photo of mine with them installed. Look real close in the photo and you can see them. Stock, you can see right down the throat and see the perforated core.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
robrooter
posted January 15, 2012 11:32 PM
any one running these as well
Ride it, Respect it, It can an will bite you when you least expect. /smilies/smile.gif" border=0>
posted January 16, 2012 04:32 AM
Holy grave digging!
But to answer your question, not too many guys here are running them. I haven't heard of anyone trying to make them louder since this thread.
Seno
BANNED FOR LIFE!
posted January 16, 2012 04:49 AM
Look like they would be easy to open up and "modify".
cls
posted January 16, 2012 07:14 AM
TBR's are pretty loud already for street exhaust. Most folks try to quiet them down. But, yes, there are several different models of tip inserts you can buy for most of their pipes. Quieter equals a little less oomph, of course. I've had quite a few on other bikes, not the 14. I'm a fan of TBR for most street bikes.
joseph702
posted January 16, 2012 05:10 PM
there deff loud for the street . nice idel but open it up every one knows ur there even the 5.0
KSP03SV1
Sit down shut up n hold on!
posted January 31, 2015 09:24 PM
TBR's end caps r a pain in the ass to remove! Easiest way I found was to heat the pipe up in the oven to about 270 to get adhesive tacky then I literally BEAT it out . As for the rivet holes I just ran a 6-32 tap through them once I got them back together and used some S.S. button head screws 3/16 long with a little silicone on the threads to prevent them from backing out. Looks good.
KSP
KSP03SV1
posted February 01, 2015 11:01 PM
KSP
tuusinii
posted February 02, 2015 04:10 AM
If you remove the packing you also lose HP...
0.2275059223175 seconds processing time
