BIKELAND > FORUMS > ZX-14.com > Thread: engine out and apart. Loose balancer shafts? NEW TOPIC NEW POLL POST REPLY
Big_T112
posted May 31, 2009 09:02 PM
Should I pull the balancer shafts and replace them with the dummy ones Schnitz sells? I have searched and really found no real good answer. It does help with oil pressure. I will ride the bike on the street.
MJ
posted May 31, 2009 11:13 PM
You're going to lose that awesome smoothness. If you're riding is mainly street I'd leave them in, I doubt you'll gain any noticeable improvement, but you will gain alot more vibes
Compton
posted May 31, 2009 11:32 PM
lose em!
b.w.
zxbob
posted June 01, 2009 03:17 AM
lose em!
+ 1
Bob
Big_T112
posted June 01, 2009 05:13 AM
OK, I will take them out and order the dummy shafts today.
posted June 01, 2009 06:07 AM
Contrary MJ,
I have spoken with many people who have removed them, and the bike ran as smooth as stock.
Use clems shaft!
NINJA12
posted June 01, 2009 12:27 PM
Why not just weld the holes in the stockers?
zxbob
posted June 01, 2009 01:13 PM
Clems shafts are cheaper than welding ..... assuming your not a welder.
Bob
posted June 01, 2009 01:13 PM        Edited By: dubious on 1 Jun 2009 21:14
loose weight for $60!
But yes that has been done too.
Big_T112
posted June 01, 2009 01:19 PM
I guess I could just weld the stock ones. It would be fairly simple. any pitfalls to welding the stock ones?
MJ
posted June 02, 2009 02:29 AM
Contrary MJ,
Use clems shaft!
I've read otherwise, I don't doubt you though Lyle I do wonder how it would be as smooth as stock though, if that was the case you'd think kawi never would have put them in in the first place. It might also depend on what different riders consider smooth. Smooth to some may be a paint shaker to others. I know my 14 is smooth as glass, smoothest bike I've ever ridden. I wouldn't want to do anything to lose that smooth lol
Big_T112
posted June 02, 2009 05:27 AM
When you take the balancer out of the old busa it does make it a little rough down low. But not like shake your teeth. On my turbo busa which was used for the track mostly you could not even tell it was out. I am going to ride it on the street mostly. The 14 is a smooth bike and I like that about it.
posted June 02, 2009 08:25 PM
The guys I know h=who did this had their internals balanced, aftermarket rods and pistons, but to be fair my stock kawi internals were within 2 grams across each cylinder!
They had carbon on them too, and I think that was what put them off!
That said I think increased rotating mass is as much the reason they have 2 balancers!
0.25343012809753 seconds processing time
