BIKELAND > FORUMS > ZX-14.com > Thread: Adding some weight to the front end? NEW TOPIC NEW POLL POST REPLY
diablozx14
posted May 27, 2009 05:42 AM
Has anyone else done this to help keep the front end down while at the track on a stock wb bike? If so where did you get the weight, where did you mount the weight and the main thing how much weight did you use?
07 Diablo Black ZX14 Dead Crawlin!
BobC
posted May 27, 2009 06:10 AM        Edited By: BobC on 27 May 2009 14:37
I run my 14 with stock wheelbase, mainly for top speed runs and occasional quarters. Due to the top speed requirements I am running 17/40 gearing and I don't have the problem of wheelies. It will pull a wheely off the throttle of course but it's easy to launch hard and still control it. (Still in the nines foot-shifting though)
It's worth mentioning that when people fit larger rear chainwheels to a bike with a stock swing-arm it pulls the wheel forward and shortens the wheelbase. If this is your problem you could try getting a link or two more chain next time you replace it. Otherwise it's just seat time and technique.
Nearly forgot to say, have you got the bike lowered? Eliminating rear squat on launch makes a big difference.
There have been some discussions on adding weight. Maybe do a search?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
14nooby
posted May 27, 2009 07:57 AM
Brocks sells it. Its called a ballast. Great Idea if you are light. It is tough to keep the front down.
diablozx14
posted May 27, 2009 07:04 PM
OK call me stupid but where does this ballast bolt to?
LLcooljebb
Upgrade I Must
posted May 27, 2009 07:30 PM        Edited By: LLcooljebb on 28 May 2009 03:36
flyboy put the ballast on the rear for land speed racing in this thread...same setup as if it were in front.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=43980
"no time to be void or save up on life
you got to spend it all.."
zx-twitch
the dude abides
posted May 27, 2009 10:21 PM
the brocks ballast is made to bolt to the rear end and provide better grip (through weight) to the rear wheel of a bike with an extended swing arm
LLcooljebb
Upgrade I Must
posted May 28, 2009 08:10 PM
I think flyboy used a ballast from someone else or constructed his own, but his system will work on the front of the bike I believe.
posted May 28, 2009 08:51 PM        Edited By: dubious on 29 May 2009 04:52
Use an olympic 7 foot 45lb bar
If they get near your lane swerve over and take em out ! LOL
posted May 29, 2009 05:01 AM
You can put wheel weights or similar under your front fender as well. I have a busa fender here that weighs 10 lbs, and made many passes without incident.
Also, filling the front axle with lead will help.
kaw-rick
posted May 29, 2009 06:34 AM
Easy to make a weight , that bolts on header. thats what i did. Hardly noticeable. I had some flat 1\2 inch bar and cut it up and made a vpattern that fit inside the front fairings perfectly. had a small hole in center. Real easy to make. I dont use 1 anymore. This was on a smeg pipe. Now i got a sidewinder. The thing prob weighed 15lbs. Wish id taken pics, it was slick. Cant believe some company isnt making 1 already.
0.30140686035156 seconds processing time
