BIKELAND > FORUMS > ZX-14.com > Thread: Installed APE manual adjuster today NEW TOPIC NEW POLL POST REPLY
davej
posted May 25, 2009 09:15 AM        Edited By: davej on 25 May 2009 17:16
The chain rattle was because the ratchet rings had rounded off so the wire spring clip couldn't hold the plunger in place. The plunger moved in and out freely which is not a good thing. Spring pressure and oil were the only thing keeping the cam chain tension in check. Rotated the engine forward and moved the bolt in until all the slack was taken up then backed off a 1/4 turn so it was no longer touching chain mechanism. Started the engine and was quiet as new. Then while the engine was running backed off the bolt 1/2 turn and the rattle started coming back. Went the procedure again and tightened the jam nut. What a huge difference, no more rattle rattle and the motor sounds like new again. Should have done this 18,000 miles ago. What I used to do to get the chain quiet was shut the motor off and restart, that stopped working so something had to be done.
Triumph guy
Big_T112
posted May 25, 2009 11:45 AM
Just be careful. If you run it too tight it will burn up the chain guide, or snap and cause all kinds of damage. sounds like you did it right.
davej
posted May 25, 2009 04:37 PM        Edited By: davej on 26 May 2009 01:18
I've owned many bikes with manual adjusters and the procedure it the same. The CB450 Honda, the CB77, CB750. some twins required that you have one of the exhaust valves opening to slacken the back side. I had put Mobil synthetic 10-40 Racing 4-T in the motor and it MADE THE NOISE WORSE ! Now I know that it was the loss of friction on the plunger catch that made the ratchet slip more. That's a good thing to know. Going back to full motorcycle synthetic.
Triumph guy
zxbob
posted May 26, 2009 03:15 AM
Great mod .... did mine along time ago !
No issues whats so ever.
Bob
87gtNOS
posted May 26, 2009 03:26 AM
It's funny that you say the oil change made the rattle!! Because my rattle started at the FIRST oil change at 600kms. I put in Kawi Synthetic. All other oil changes are now Motul, and the rattle remains.
Ordering the APE tensioner today, I just don't have the time to install the Concours tensioner at the moment.
01 ZX12R
davej
posted May 26, 2009 04:27 AM
Slicker oil makes the problem worse, tired oil or old oil lets the cheezy catch hold better.
Triumph guy
87gtNOS
posted May 26, 2009 04:46 AM
davej, it will be interesting to compare the Concours and ZX14 adjusters side by side when I get mine out for the APE install.......
01 ZX12R
davej
posted May 26, 2009 03:22 PM
Took a close look at the tensioner today and it seems to be working as designed. It is supposed to extend without something to stop it. Very well could be that all the travel has been used up. It is allowed to move back and forth .190" before it sets to the next notch. When you install the APE check the distance adjusted, to the amount of travel allowed in the stock tensioner. If the bolt is at the full extension of the stock range limit then the tensioner has no more travel hence the rattle. If is in the service range then the .190" may have something to do with it. Have always hated auto tensioners.
Triumph guy
87gtNOS
posted May 26, 2009 03:27 PM
Maybe I need to go out on the highway and rev the shit out of the bike in an attempt to get it to click to the next adjustment!!!!!
01 ZX12R
posted May 26, 2009 03:39 PM
zx12 tensioner modified... got mine from Bill Eason...
BTW, the cam chains on the 14 suck ....
posted May 26, 2009 08:54 PM
WHILE I WAS LOOKING UP THE PART NUMBER FOR MY STRETCHED CHAIN, I NOTICED THE TENSIONER HAS BEEN SUPERCEEDED... THERE IS AN UPGRADE FOR THE 06 AT LEAST, BUT UNLESS YOU TAKE OUT YOUR MOTOR, YOU DOUBTFULLY WILL GET ONE FOR FREE...
I GUESS IT STILL ISN'T REPLACED FOR NOTHING, SO AS THEY SAY NOTHING EVER IS REALLY FOR FREE
Acat
posted May 27, 2009 06:41 PM
Mine is noisy @ 6900 miles. Where can I get an APE?
gilberjj
Friend of Fast
posted May 27, 2009 09:37 PM
Need more info on the zx12 mod, or the updated zx14 tensioner.
blackbullet76
posted May 27, 2009 11:26 PM
I just ordered me an APE manual tensioner for my 14. Can't wait to get it installed and say goodbye to the rattling!
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
zxbob
posted May 28, 2009 03:38 AM
http://zxzone.com/sprockets.html
Bob
87gtNOS
posted May 28, 2009 04:42 PM
$89 CDN.....I'll pick mine up next week.....
01 ZX12R
01smokes
posted May 28, 2009 05:03 PM
how hard is it to put them on?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
87gtNOS
posted May 28, 2009 05:04 PM
Takes 10 mins I bet.
01 ZX12R
gilberjj
Friend of Fast
posted May 28, 2009 06:02 PM
bump for more information.
how long to install
how often check tolerances
how hard to adjust
how easy to adjust (what tools it takes)
best place to buy?
davej
posted May 28, 2009 06:27 PM
4mm hex allen, 5mm allen , #2 phillips, 8 mm socket with 1" extension, If you have to ask consult your service dept. Crap they might not know as well. I hate to say this but Honda shops are very up on adjusting manuals.
Triumph guy
posted May 28, 2009 06:29 PM
I predict a rash of worn cam chains within a year.
LLcooljebb
Upgrade I Must
posted May 28, 2009 06:41 PM
LMFAO!!!
"no time to be void or save up on life
you got to spend it all.."
87gtNOS
posted May 29, 2009 04:11 PM        Edited By: 87gtNOS on 30 May 2009 00:12
FOR SALE.......I have a brand new (never installed) CONCOURS 14 tensioner.
I just can't be bothered with installing it...have to remove the valve cover, etc....
$60 US shipped.
Part Number: 12048-0047
gotnos51@hotmail.com
01 ZX12R
blackbullet76
posted May 30, 2009 05:14 AM
$60 US shipped.
How does it differ from the ZX-14 tensioner?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
zxbob
posted May 30, 2009 06:49 AM
$60 US shipped.
Cause I guess you have to take off the valve cover ...
Bob
0.40884113311768 seconds processing time
