BIKELAND > FORUMS > ZX-14.com > Thread: So.... Its pretty much complete! NEW TOPIC NEW POLL POST REPLY
Compton
posted May 20, 2009 11:37 PM
b.w.
Compton
posted May 20, 2009 11:43 PM
Oh Hai!
b.w.
serius blk
posted May 21, 2009 12:28 AM
i like it. compton is that the zx10 fender mod
juicey69
slowpoke
posted May 21, 2009 03:04 AM
looks like that imo
Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles ..." - Hunter S. Thompson
posted May 21, 2009 03:49 AM
Looks good! Like the wheels
posted May 21, 2009 05:53 AM
looks good
posted May 21, 2009 05:54 AM
nice!
zxbob
posted May 21, 2009 05:59 AM
Who did the seat ..... looks great !
Bob
Compton
posted May 21, 2009 06:20 AM
b.w.
Compton
posted May 21, 2009 06:21 AM
Bob
It's a Tobin seat.
b.w.
Compton
posted May 21, 2009 06:23 AM        Edited By: Compton on 21 May 2009 14:23
Started with just a simple swing arm install. I couldnt stand, repeat stand the factory frame, subframe, well everything black with the metal flake in there. Just never looked clean, always hazy from the flake.
Pretty much how it looked last year before the redo
Tear down started in November
Now its time to have fun, powder coat everything! frame, subframe, swing arm, lower forks, brakes, both upper and lower triple tree, clip ons, engine mounts, engine covers and i mean everything just solid black.
With the help of the powder coater, we were able to do the wheels. pretty much a dead on for the candy plasma blue kawa paint, but powder coat. centers where done in black to match everything else.
Now, time to put it together.
Had the upper fork tubes anodized black, since i couldn't stand the gold color. Lowers were done in black.
Here is a shot of the dash, all coated up
b.w.
posted May 21, 2009 06:43 AM        Edited By: dubious on 21 May 2009 14:45
Nice work.
I fully understand the effort involved, and the attention to detail.
Alot of anodizing and powdercoating in your project there.
I was thinking of anodizing the axle blocks and the nuts too, but they get handled / wrenched alot and figured they would show it pretty quick.
The rizoma's look good
Who's air shifter bracket is that?
Would it work with vortex rearsets?
slates
posted May 21, 2009 06:45 AM
looks great...tasteful and not overdone...love the reservoirs.
you must have had those forks shortened since I don't see a strap nor are they lowered in the top triple clamp.
swingarm is perfect length for the right look for the 14.
posted May 21, 2009 06:46 AM        Edited By: Shane661 on 21 May 2009 14:48
I was wondering about the shifter bracket myself. It seems like you are giving up a lot of leverage with that setup though? I'm sure it shifts fine, just wondering what the advantage might be?
What type of cylinder is that? It must act in reverse?
Compton
posted May 21, 2009 06:48 AM
Im not sure, friend of mine picked them up for me. ill see where he found them. It wouldnt work with the vortex rear sets, the way it connects to the stock shifter, just isnt do able.
weld up all the holes now that its sandblasted!
placed a piece of bar stock where the stock well nuts are, so i never have to worry about them falling into the engine.
b.w.
Compton
posted May 21, 2009 06:51 AM
yes, the forks are internally lowered around 3 inches. i'm not a fan of straps, and hate seeing 2 inches of fork tubes sticking out of the triple tree. just pet peeves
b.w.
posted May 21, 2009 06:52 AM        Edited By: dubious on 21 May 2009 14:52
I did the same but welded threaded inserts in the well nut holes
Gettin ready for a turbo????
What length is the arm?
Compton
posted May 21, 2009 06:54 AM
IMO, there is plenty of leverage when you see it in person. its right on the output shaft on the trans. I didnt like the look of seeing a big shifter hanging off the side. plus it got in the way of my spring on the kickstand. this setup its tucked away, the solinoid is right on the tube, and its all AN line without comnig close to the frame to scratch anything
All of the cylinders move in which direction you put the supply line. on the bottom port, pulls in. top port, pushes out. its a Jr cylinder, i believe its a pingle but i forget.
b.w.
Compton
posted May 21, 2009 06:57 AM
it's the "brock" mcintosh, alumipro. 2" - 8" over. air tank, now being used as a catch can breather, and 2lb bottle holder perfect for my co2 shifter! i should be able to get almost a full year out of it before i have to fill it.
turbo........ always plan ahead. i stated back on zx14ninja forums in the day that i know i can build a very nice turbo kit for under 3k and i still plan on doing so. have been collecting parts so we'll see what happens over fall/winter this year.
b.w.
Compton
posted May 21, 2009 07:04 AM
here is another shot of the arm with the crankcase hose going to it. should work, friends do it to there 1k and busas. dunno, we'll see!
also note, the hayabusa ohlins dragshock doesnt clear the fuel pump. ended up with a 08 busa spring on the stock shock and had it redone by adams performance. same shock they use on the there pro street 14.
b.w.
masszx14
A mind beside itself!
posted May 21, 2009 08:29 AM
Does the 08-08 zx10 fender mount on Lyle's brackets?
I might get one, looks really nice
Anyone looking for an OPP carbon fiber 04-07 zx10 front fender?
universal@mind
Compton
posted May 21, 2009 08:39 AM        Edited By: Compton on 21 May 2009 16:41
No, the 08 09 fender does not work with older year zx10 fender brackets. totally different.
b.w.
Compton
Also, to show how much more i like the zx10 fender. We cut off the 14 fender mount, sanded it and rounded it before powder coating.
b.w.
Compton
posted May 21, 2009 08:43 AM
o yah, here it is last year when i bought it brand new. Next weekend will be the 1 year
b.w.
Compton
posted May 21, 2009 08:46 AM
one week later. had the forks internally lowered, flys out, brocks 200mph kit and added HIDs
wow time goes quick
b.w.
0.35194802284241 seconds processing time
