BIKELAND > FORUMS > ZX-14.com > Thread: clutch problem NEW TOPIC NEW POLL POST REPLY
peterloo
posted May 18, 2009 07:52 PM
clutch problem
Hi,
I have an 08 that I purchased new in April of 2008. Prior to reaching 12,000 miles, I noticed the clutch slipping. For example, when I have the clutch engaged in 1st at a complete stop, I hear a VERY low clank like a gear is engaging and the bike slightly inch forward for a split second. This doesn't happen all the time, but seem to be happening more often lately. I am wondering if anyone else is facing this very same problem. I do have two years extended warranty on the bike so I will be taking it in to have it checked out, but was wondering if this is a known issue.
I am not rough on my bike nor am I an expert racer. I have taken it to the track only once and did one run so the bike has been pampered most of its life on the road.
Thanks.
Peter
Smooth_G
posted May 18, 2009 09:49 PM
u mean your clutch is draging,,,they all clunk,,if u hold it in for a few seconds then kick it in gear sometimes it wont clunk,,but they r clunkers,,lol,,lol,
Bently
2012 14r In Blue and no Mods!
posted May 19, 2009 03:05 AM
Sounds like your clutch is worn and don't take offense to this but I've seen guys wear a clutch out in 1000 miles on the street because the slip it when taking off from stops and don't even really know they are doing it. IMO 12000 miles on a clutch is not bad. but if it is worn I don't think your warranty will cover it.
BobC
posted May 19, 2009 03:32 AM
The "clunk" you hear and feel is quite normal when you start the engine from cold and engage first gear, it's the clutch freeing off. It shouldn't do it after that though, if it does then you have clutch drag meaning it's not disengaging completely.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
peterloo
posted May 19, 2009 08:52 AM
Actually I am aware of the clunk shifting into 1st is quite normal. The problem that I am having is when I am already in 1st and the clutch is engaged. It appears as though the gear is engaging slightly which in turn forces the bike to move slightly forward. This does not happen every time, but it appears to be happening more often.
karamjit242
posted May 19, 2009 01:11 PM
12000 miles and clutch problem. with proper use clutch should last forever.
List of problems with zx14
1) over heats
2) uses engine oil - some bikes
3) clutch problem - this is the 3rd case i have heard of.
4) squeaky brakes.
makes me think if i should just buy CBR or z1000
2007 zx14 pearl white
peterloo
posted May 19, 2009 01:43 PM
karamjit242, I think like people, all bikes have there good and bad. I am quite happy with ZX14. Honestly speaking, the ZX14 is an all around great bike. I have take long trips in the southwest. My only complain is the heat. But then I live here in the hell hole so I shouldn't even make any comments about heat. I have never ridden a powerful bike like this ZX14 until I purchased it about a year ago. One of my riding buddies own a Busa and I love it also. Just like my bike, it is hot as hell and fast. Busa seems to handle better in the tight swisties, but I like my ZX14 better on long trips. My other buddy owns a CBR1000 and is regretting the purchase of it. Although he won't admit it, I know he is unhappy as he never rides it much. Quite frankly, I am a motorcycle enthusiast so I like all bikes. But if I have to purchase one, I tend to lean towards Kawasaki as I have always owned Kowies. My recommendation is to go to a bike show and ride all the bikes and make your decision thereafter. I am planning on purchasing a Vulcan 2000 later this year.
Bently
posted May 19, 2009 02:25 PM
1) over heats
4) squeaky brakes.
Let me guess your new to bikes? Clutches don't last for ever in any bike or car for that matter, how do you think a clutch will last forever?
karamjit242
posted May 19, 2009 02:32 PM
toyota pickup 100k miles clutch still works.
suzuki GS 500 30k miles bike is dead but clutch was fine till the end. i am not new to bikes. had gs500, z1000, cbr 1000, vtx 1800, hayabusa, r1 and now zx14. -->05 cbr and 05 z1000 my best bikes. 07 hayabusa (idle problems) and02 GS500 (carb problem) where my worse bikes.
Wheelie
Old Man
posted May 19, 2009 03:36 PM
1) over heats
4) squeaky brakes.
you're wrong Bently, a Poser could probably get a life time on the 14 clutch, speed never over 65mph, very slow take off's from redlights. hehehe
wee
posted May 19, 2009 03:38 PM        Edited By: dubious on 19 May 2009 23:40
The toyota and gs500 are severely underpowered for the clutch they use.
Unless abused or misused I would expect the pilot bearing to wear out first , as often does with cars.
If the clutch is abused, misused , dragged, or for some reason does not retain hydraulic pressure and allows it to drag while the lever is pulled it will wear out...
Of course there is purposeful abuse like slipping it for wheelies, or drag racing as well.
We all expect to have to replace a clutch that see's use like that though ...I would hope...
BTW, the zx14 is reknown for having the most stout clutch and transmission installed in such a bike...
posted May 19, 2009 04:07 PM
if you toasted a zx-14 clutch you tried real hard, or you really slip it. this bike has the best clutch made
wndsrfr
posted May 19, 2009 04:57 PM
has the fluid level dropped in the reserve--if so a leaking hydralic clutch line or air in the line
would also cause this
as the line looses pressure the clucth will "drag"
Bently
posted May 19, 2009 05:02 PM
1) over heats
4) squeaky brakes.
wee
Depends on what you call life time a guy that puts 12000 to 15000 miles a year on his 14 is going to go thru a clutch every couple years if rode easy.
INTIMIDA2OR
RED rider!
posted May 19, 2009 09:58 PM
48,000 miles with the original clutch with regular trips to the dragstrip and 0 problems
'06 Passion Red ZX-14
*Lee*
bruno nadeau
posted May 20, 2009 01:47 AM
50000 miles on a 06 no drag strip sometime riding hard on the street 0 problem exept frame check for crack it was ok.
bruno nadeau
Wheelie
Old Man
posted May 20, 2009 03:14 AM
wow.
wee
TooHype
Go Hard or Go Home !!
posted May 20, 2009 03:26 AM
pissear
Professional Cockis Slap Peer
posted May 20, 2009 06:27 AM
1) over heats
4) squeaky brakes.
List of counter your problems with my 14
1) makes heat = HP
2) uses engine oil - if you overfill
3) clutch problem - I've heard an aftermarket lever burned out a set of clutches. I don't think my pressure plate moved in to show wear since I bought it is beat it hard.
4) squeaky brakes - I have the same parts as you on your bike. I do not hear anything out of my fronts. I never heard anything out of the back brake = I do not use it.
5) makes me think if I should just bye-bye past that slow ass CBR or z1000 with all of the same trouble above is not mine, but bike for bike is match your problems against the same azz mine, which has zero problems.
666) Stranger evil things have happened wear out only your hair dress her knows fur sure.
I have my riding gear on... I am ready for bare is get a lane, squeak key pants. Bring year parts. No, I'll ear you cum inn.
peterloo
posted May 20, 2009 07:52 AM
Actually, I have not checked the fluid. Thanks for the tip. I have been enjoying my 14 for the past year and have regularly taken it in for service so I have not taken the time to get acquainted mechanically. I think it is about time that I do. Thanks again.
0.23024892807007 seconds processing time
