MJ
posted May 16, 2009 02:16 PM
Was going to add second cooling fan...decided not needed
I was going to order a second fan kit for my 14, but decided to be sure it was needed. I idled the bike in my garage on an 80 degree day for 23 minutes, the temp gauge went up to one bar above the middle and stayed there rock solid for most of the 23 minutes as the fan cycled on and off. I got the impression it could have did that all day, so no 2nd cooling fan for me. I don't think the money and time is needed
I also looked over the welds I could see, they looked great, nice and even, no cracks and the bike purred like a kitten. Its nice when things work like they should
FastestBusaAround
I eat Fish...
posted May 16, 2009 03:03 PM
Wish my bike would do that, it goes to the 2nd bar down from the top...and it does run noticeably hotter than my 06 did.
FYYFF!!!
posted May 16, 2009 03:29 PM
Steve,
I would try pulling the timing back to 2 degree's advanced, maybe stock if that doesn't help.
Although nobody has stated or noted the timing was changed for 08.
Now I think it was.
It sounded like you were more than happy with the power anyway.
Bluebyyou
Gettin My Curve On
posted May 16, 2009 03:57 PM
Mine ran cooler after it got some miles on it, a full exhaust, and a tune.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
Seven
posted May 16, 2009 06:52 PM
Mine will do the same as far as if im sitting in the garage the fan will come on and off but once i get out on the road and begin to take it through the paces and then roll back into town it begins to get hot. Not sure how mines going to do when its 105 out and sitting in traffic!!! I already have wrapped the headers and engine ice. Im still thinking about it on mine
project in the works!!! +4 mil stroker falicon rods CP pistons, APE valve springs, head studs, high pressure oil valve, muzzy HD oil pump plate, Adams performance 2" pan and Tsukigi sidewinder, lowered 2"
TampaSmitty
posted May 16, 2009 07:30 PM
ive noticed here in GA that both my 06 and 07 are 1 bar from top in traffic at 80+degrees.
engine ice for my 06 was a 1 bar drop. never had a prob after that. even at 90+degree days.
but this 07 is a wee bit quicker to get hot. engine ice is my first step for this one.
06 1st gen zx14,muzzy full exhaust, pc3,no flies tuned at 180rwhp and sold after 15500miles with leaky valve cover bolts and a shreaded back tire.
now 07 ,corbin hardbags
pc3, muzzy m14 ,flies out..
FastestBusaAround
I eat Fish...
posted May 16, 2009 07:35 PM
Now I think it was.
I may give that a try...it pulls so fucking hard, it may not make much difference in that department, but may make it run cooler, as you said.
FYYFF!!!
Old Guy
posted May 16, 2009 10:59 PM
I installed a switch for traffic on hot days. It works.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Beondwacko
posted May 17, 2009 04:26 AM
quote: I installed a switch for traffic on hot days. It works.
Did you wire it directly to the fan or did you find the relay that controls the fan and energize it that way ?? I was looking to do the same thing but wasn't able to find the relay.
posted May 17, 2009 05:25 AM
no problems here in sunny florida. i run engine ice just because i flushed the system and had to put something back in. i run an aftermarket exhaust which definitely helps but in many traffic situations and hard running no problems with the stock setup of one fan. almost 11000 miles and runs better all the time.
blackbullet76
posted May 17, 2009 05:37 AM
Drag racing get's mine hotter than anything. I usually do 3 passes and let it cool off. It get's to 2 marks above half sometimes.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
MJ
posted May 18, 2009 11:44 AM
I'm going to keep a good eye on my during some nice hot hard rides, then hitting traffic. Its been a long off season for me, but from what I remember last year I didn't have any real heating issues to speak of. I've been wanting to put the second fan on for awhile now, but I was still suprised how well it did idling and getting spun up a little in the garage for 23 minutes though. I have to admit I thought it was getting a little hotter than that in actual traffic. I might do a manual fan switch while its apart instead
Sticks_n_Stones
posted May 18, 2009 01:07 PM
If you want better cooling but dont want the hassle of installing a second fan, then get the Muzzy fan. Its dead simple to put on and flows noticeably more air. How do I know? Because now my legs get REALLY warm on hot days. Seriously though, it is legit and works as advertised. Drawbacks are its noticeably louder (no big deal, but you definitely know whether its on or not), and most of them hit the upper fan shroud and you MUST trim it or you end up with the aluminum fan chewing through it with a godawful noise, then the fan is out of balance enough to make more noise than it should. Ask me how I know... still worth it though.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted May 18, 2009 01:42 PM
prob comes when you turn engine off while bike is hot in hot temps.. get bike hot... turn engine off for a minute or so, then turn back on. fan shuts off when bike is off so heat builds up - repeat this cycle (ie: in traffic or multiple city stops) and you could end up in hot water (so to say).
posted May 18, 2009 02:15 PM
quote: no problems here in sunny florida. i run engine ice just because i flushed the system and had to put something back in. i run an aftermarket exhaust which definitely helps but in many traffic situations and hard running no problems with the stock setup of one fan. almost 11000 miles and runs better all the time.
+1
none of our west coast scorching weather FL ZX14 bikes ever ran hot. I keep seeing folks post about this strange phenomenon
posted May 18, 2009 03:02 PM
quote: prob comes when you turn engine off while bike is hot in hot temps.. get bike hot... turn engine off for a minute or so, then turn back on. fan shuts off when bike is off so heat builds up - repeat this cycle (ie: in traffic or multiple city stops) and you could end up in hot water (so to say).
WELL if that's a problem do this > Turn the bike off and then turn it back on without hitting the starter button ..The fan will run till the temp comes back down ...I have done that a few times at the track after hot lapping 5 or 6 in a row . It cools down real quick but make sure your battery is up to snuff or you might be walking home ..
MJ
posted May 19, 2009 11:23 AM
Nice tip Lee thanks
tech73x
posted May 19, 2009 11:58 AM
Another option is to wire in a permacool adjustable fan controller and put the probe in the upper right hand portion of the radiator. The adjustability and the installation was easy, In traffic riding and parking the fans will run for about 1-2 minutes after you shut the bike off. It ultimately solved the fan problem in my opinion. I also have a 2nd fan with this setup,,
Old Guy
posted May 19, 2009 06:11 PM
Edited By: Old Guy on 20 May 2009 02:13
Power directly from a terminal strip (use the strip to power other things also) I have mounted on a air duct to a switch then tape into the fan side of its connector not the wiring harness side.
That way the relay can turn on the fan when it is triggered or I can override 'manually'.
Got real tired on the kill switch game.
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Douglas Home
posted May 19, 2009 08:08 PM
The fan relay (from memory) is on the left by the ecu .
But I just put an override switch , in parralel , to the thermostat.
Also added Liquid Performance coolant and had no troubles here in the tropics!
Doug Mackay Australia
