BIKELAND > FORUMS > ZX-14.com > Thread: Swtiched 12V Location, For Shift Light?? NEW TOPIC NEW POLL POST REPLY
posted May 14, 2009 05:32 AM
Is there an accessory lead somewhere convenient? I am trying to install a shift light, and I need a switched 12V lead...
Thanks!
kawasakijockey
posted May 14, 2009 05:45 AM
If you dont have the horn on your bike use the hot from it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted May 14, 2009 05:47 AM
I'll have to look at that. I think my shifter taps in there...
Any others?
06redzx14
posted May 14, 2009 05:50 AM
I used the hot from the running lights
posted May 14, 2009 07:12 AM
Running lamps! either one, convenient location for low amp needs like a shift light.
posted May 14, 2009 07:35 AM
I ended up using the loom from the air shifter. It already had spade connections for the horn. Thanks for the suggestions!
pazx14rider
posted May 14, 2009 08:56 AM
theres also a empty plug in the tail of the bike that has switch power I tapped into that.
pazx14rider
posted May 14, 2009 08:57 AM
If you got the msd shane set it up for 1 clynder operation.
posted May 14, 2009 09:29 AM
10-4, discovered that...
pazx14rider
posted May 14, 2009 09:43 AM
I just sent mine back to msd for repairs. Dont let it get wet I think thats what happened to mine. I will post up and let you know how the service was I bought it in january.
0.21632099151611 seconds processing time
