BIKELAND > FORUMS > ZX-14.com > Thread: K&N filter modification NEW TOPIC NEW POLL POST REPLY
06redzx14
posted May 12, 2009 12:04 PM
I'm looking for information about modifying a K&N filter for better flow. I remember seeing a post about it on another forum, but it is no longer available.
posted May 12, 2009 12:19 PM
The stock ones have a backfire screen, the K&N does not.
LLcooljebb
Upgrade I Must
posted May 12, 2009 08:41 PM        Edited By: LLcooljebb on 13 May 2009 04:41
Modify K&N by replacing with BMC! lol
Bump for modification info as well...I run a BMC, but alot of guys run the K&N (would be good info to have posted).
"no time to be void or save up on life
you got to spend it all.."
INTIMIDA2OR
RED rider!
posted May 12, 2009 11:49 PM
+1
'06 Passion Red ZX-14
*Lee*
joemugg
posted May 13, 2009 06:53 AM
Speaking of air filter mods... What year did Kaw switch to a metal air filter door?
'97 GSXR600 street sweeper
WindSwordNinja
posted May 13, 2009 06:59 AM
I know my '08 has one but I don't know it that was the first year.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
zxbob
posted May 13, 2009 07:53 AM
I have never heard of a modification to a K&N filter. I do know guys were modifying
the stocker and the pipercross !
Bob
DogoZX
posted May 13, 2009 08:01 AM        Edited By: DogoZX on 13 May 2009 16:02
'08. The '06-'07 models have the crappy plastics ones. On a side note, I recently ordered one from Babbit's only to inquire four weeks later as to why it hadn't showed up yet and was told that they are on backorder. So I bought on from Schnitz. It was in stock and at my door in less than a week.
masszx14
A mind beside itself!
posted May 13, 2009 01:47 PM
I switched mine awhile back and showed up right away.
Good mod for a piece of mind
universal@mind
JDC
posted May 13, 2009 04:26 PM        Edited By: JDC on 14 May 2009 02:14
If you are maning using the OEM placement, about the only thing you can do is have a K-N (cotton) filter or BMC. They flow the best you can get.
The only other option is to have more Sq inches of contact patch, which would mean re-doing your filter placement and maybe your intake top allow for more filter area.
Example: K&N's formula, sqaure or rectangular filter:
L * H * 6 (which includes the frame of the K&N filter) = CFM within 7-10
Now, before you go to that work to find out it made no meaningful difference, or very little difference, first get to the dyno, do a few pulls with the filter you have (say K-N), and then remove the filter and do a few pulls. You'll see if there is much difference without a filter (optimum flow at that setup). If there is a large difference, then it may make sense to do up a new filter.
I don't think you'er going to see much difference between a K&N on this bike and a mod'ed filter.
Other bikes, maybe, like the M109, a moded filter can make a huge difference - say 15-17 HP more, just for a max'ed out filter, Once you have a free flow pipe. Attribute 5 for the pipe, lets say = 22 HP gain total then. That bike requires quite a bit of mod'ing of the air box. and making up a one off filter. Doing that you can equal having no filters or no airbox in HP and TQ. The OEm filters flow about 143 CFM, of so, if I recall. The maxed out filter flows about 760-780 CFM.
0.21892094612122 seconds processing time
