BIKELAND > FORUMS > ZX-14.com > Thread: Aftermarket Shift Lights? NEW TOPIC NEW POLL POST REPLY
posted May 09, 2009 06:01 AM
Has anyone installed an aftermarket shift light on their 14? How hard is it to do? Which model did you use?
I've seen one from Boost By Smith, but I'm interested in any other options out there.
criszx14
posted May 09, 2009 07:03 AM        Edited By: criszx14 on 9 May 2009 15:05
I use the MSD Part# 89631 from schnitz Easy to install. VERY BRIGHT
I mounted mine to the top of the gauges
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4815327&showprevnext=1url
posted May 09, 2009 07:14 AM
same one as cris
Compton
posted May 09, 2009 07:46 AM
i have the raptor shift light.
b.w.
06redzx14
posted May 09, 2009 08:41 AM
x2 it's super small and super simple to wire
pazx14rider
posted May 09, 2009 09:05 AM
I have the MSD, last nite it didnt work. I think its because i got it wet when i washed the bike before going to the track. Hook up was simple, once you figure out which wire to pickup the signal. heres a pic
posted May 09, 2009 11:58 AM
Where did you guys tap into for the signal?
posted May 09, 2009 12:44 PM
I used coil #4 , and schnitz tach adapter pigtail... no need tom splice into harness....
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4951875&showprevnext=1
pazx14rider
posted May 09, 2009 03:24 PM
coil #4 signal wire I beleive it was the white with red tracer. The msd comes with a pickup that you just loop the wire. then tighten a clamp over the signal wire.
pazx14rider
coil #1 signal wire I beleive it was the white with red tracer. The msd comes with a pickup that you just loop the wire. then tighten a clamp over the signal wire.
pazx14rider
posted May 09, 2009 03:25 PM
sorry I goofed It wouldnt pick up the signal on #4 thats why the second thread is stating #1
posted May 09, 2009 04:38 PM
Thanks for the info, I'll either get the MSD or Boost By Smith part...
posted May 09, 2009 04:47 PM
Shane, want my Dyna Shift minder?
BIG BLUE_ZX14
posted May 11, 2009 10:11 AM
Shane, thanks for asking this question...I asked the same question not more than 30 days ago and didn't get anywhere near the same response as you.
2007 Blue ZX14 Gone...
posted May 11, 2009 12:47 PM
I ordered the MSD today, and coil pigtail. So hopefully I'll be able to try it out later this week. When I do, I'll update my thread with the details.
pazx14rider
posted May 11, 2009 01:51 PM
Any questions on the hook up let me know shane.
posted May 11, 2009 05:40 PM
a local guy had the msd on his 10R. he said it wasnt very bright, so it will be interesting to see your opinion
posted May 11, 2009 08:25 PM
I would see spots if I looked right at it.
0.21458792686462 seconds processing time
