BIKELAND > FORUMS > ZX-14.com > Thread: 3 Hole Links...Measurements? NEW TOPIC NEW POLL POST REPLY
posted May 05, 2009 07:28 AM
Does someone have a set of 3 hole lowering links that they can measure? I am interested in the distance between holes, primarily on the lowest setting. I believe most of these links go about 3" lower than stock Max...but I would need to know that as well.
Thanks...
bsebastian
posted May 05, 2009 08:22 AM
I don't know if it matters on the brand but I have Diamond Powersports links and they say in Parts Unlimited that the settings are 1.5 and 3 inch. Measured 6 7/8, 7 1/2, and 8 1/16TH center to center of each bolt hole on mine that are sitting here. Don't have stock ones here to go off of. Sorry. Hope this helps!
posted May 05, 2009 08:32 AM
Thanks! That is what I needed to know!
eb2318
zx14
posted May 05, 2009 08:34 AM
my stock ones are 7in center of hole to center. my lowering links on my bike are 8in center of bolt to center. I have them in the bottom hole and i have 3/12 clearance from tire to stock undertail. Hope that helps you any
i luv my zx14
posted May 05, 2009 08:36 AM
Yes, it does. I currently have my adjustable links at 7.75", center to center. I am going to lengthen them a little after getting this info. I have increased clearance with my undertail and fuel pump already.
LAB3
posted May 05, 2009 04:29 PM
Shane I have Muzzy Gold 3 hole links 7" 7.5 and 8" center to center.
posted May 05, 2009 07:48 PM
Perfect, I am going to try setting them at 8...
0.23425912857056 seconds processing time
