BIKELAND > FORUMS > ZX-14.com > Thread: 09 vs 07 NEW TOPIC NEW POLL POST REPLY
zerotahero
posted May 04, 2009 04:23 PM
09 vs 07
can someone tell me the differance between the 09 and the 07 pros and cons if any?
thankyou
posted May 04, 2009 04:50 PM
thankyou
I have an 06 and 09 , as far as power it feels a tiny bit better but i will not really know till the 09 has the same mods as my 06 ...The 09 does feel a bit more refined ...
Meangreen14
posted May 05, 2009 07:37 AM
09 ZX14
I just bought an 09 14 and have a question about break-in, I almost have 600 miles on the clock can I open her up after 600ml or should I wait till after 1000ml. I am going 2 change the oil & filter at 600ml
Nimo
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
posted May 05, 2009 07:41 AM
The 08 same as 09?
posted May 05, 2009 09:43 AM
The 08 same as 09?
Yes as far as i know ...I have not heard different..
posted May 05, 2009 09:44 AM
Nimo
Change the oil and give it hell ... No need to wait till 1000 miles 600 is pleanty.... Mine go right from the dealer to the track ....
NinjaofDoom
posted May 05, 2009 11:30 AM        Edited By: NinjaofDoom on 5 May 2009 19:31
+1 My dealer told me to stay under 4k for 500 miles. I warmed it up fully and hit 9k on the way home from the dealer..... Bike runs hard and strong.
Someday we'll look back on all this and plow into a parked car.
gilberjj
Friend of Fast
posted May 05, 2009 11:32 AM
Give her piss and vinegar!!!
14nooby
posted May 05, 2009 01:35 PM
They love the abuse. The hell with breaking it in. Mine had 500 when I took it to the track.
14nooby
posted May 05, 2009 01:42 PM
The 07 and 09 are different but 08 is same as 09. I read somewhere that the 08-09 model has bigger fuel injectors or bigger throttle bodies by a few mm. I also read that the power is smoother through the entire rpm range on the 08-09 due to re engineering. I promise I did not make this crap up. I did read somewhere. My 09 seems to run more mph than all of the 06-07 models with similar mods at the track. Smokin or Shane661 knows more.
Bawls
re-learning to ride
posted May 05, 2009 02:08 PM
my dad's 09 mph's like a motherfucker. He's still trying to get used to the transition from cruisers to sportbikes and on 1.7-1.8 60fts the thing runs 6.60 @ 117.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted May 05, 2009 03:05 PM
the "go easy on it" break in method is outdated. with todays more precise builds, a few heat cycles and take to to the races. give it hell
LLcooljebb
Upgrade I Must
posted May 05, 2009 10:50 PM
I think the only real differance is injector size/spray angle,mapping, and color (looks faster, lol)...most people I've heard from say the 09 is stronger (subjective...they're likely the same bike after mods). I thought I was wrong once, turns out I was just mistaken!
"no time to be void or save up on life
you got to spend it all.."
0.41628789901733 seconds processing time
