BIKELAND > FORUMS > ZX-14.com > Thread: 2008 Engine in 2007 Bike? NEW TOPIC NEW POLL POST REPLY
posted May 03, 2009 07:29 AM
What is involved with this swap? Will the 2008 hook up to the existing wiring harness? Or can you use the 2007 harness, throttle bodies, and injector setup?
If anyone knows the full details, I'm all ears.
Thanks!
northernkaw
posted May 03, 2009 07:53 AM
you should be able to put the 08 motor in and leave all 07 electroics and injectors in tack. the motors are pretty well the same. the only difference on the throttle bodies are the injectors.
posted May 03, 2009 07:56 AM
+1 easy swap ..
posted May 03, 2009 08:01 AM
Thanks, guys. I occasionally see a deal on an 08 motor, and just wanted to know...
posted May 03, 2009 03:05 PM
The 08 injectors are better too !
Better spray pattern, and bigger!
I was told the old ones were 33 lbs, and the new ones are 40 lbs... thats good news for guys with nitrous or big motors and don't want to increase fuel pressure.
freddie900
zx 14 2007
posted May 03, 2009 06:24 PM
How much are new 08 and are they good for stock 07motor? will they fit 07 fuel rail.
posted May 04, 2009 11:48 AM
Not sure on price, they will bolt straight in , but will need a remap.
kawboy81
Busa Eater
posted May 04, 2009 12:40 PM
hmmmm, thats some good need to know info..... what about just putting the injectors from a 08-09 onto a 07?
07 LE bolt on bike
zx-twitch
the dude abides
posted May 04, 2009 02:08 PM
there is one more difference not that it makes and difference power wise but the 08's have a delrin sleeve in the engine to make the came chain quieter.
freddie900
zx 14 2007
posted May 04, 2009 08:29 PM
Wonder what kind of hp & torque increase will that give 07 with a Brock/custom map?
0.22848105430603 seconds processing time
