BIKELAND > FORUMS > ZX-14.com > Thread: main bearing NEW TOPIC NEW POLL POST REPLY
creepdog
posted May 03, 2009 06:16 AM
main bearing
if u spin a main bearing does your oil light have to come on?i busted my oil pan at the track back in october,and this past month it just started with a slight knocking noise.oil pressure was checked and was good.had a valve lash noise ever since i put the the oil pan on though.tried adj. the balancers just to see if it was that cuz it sounded like the noise was coming from that area.the next couple days after was when i started hearing that slight knock noise.cant hear it unless the bike is hot.could i have not adjusted the balancers right?
full trc pc k&n filter pulled flies stacks ign. advancer custom mapped
posted May 03, 2009 06:21 AM
Could be the adjusters, usually the rod brgs go before a main... they run much hotter and the mains all support the crank assembly together, wheras a rod bearing supports itself and the piston,
FYI #3 rod brg is the one that usually goes south first, if they do go for some reason
Bently
2012 14r In Blue and no Mods!
posted May 03, 2009 06:25 AM
Did you have it shut off before all the oil ran out? If so I would think it has nothing to do with the busted pan.
creepdog
posted May 03, 2009 07:28 AM
thanx.yeah i cut it off before all the oil drained out.
gilberjj
Friend of Fast
posted May 03, 2009 10:32 AM
You just need to rev it harder and pretend you don't hear anything....
LA LA LA LA LA LA LA
creepdog
posted May 03, 2009 10:59 AM
lol.i dont hear it when im riding,only when im sitting still and i rev it a lil bit.just adjusted the balancers again.not as loud as before but im gonna go ride it for a bit and see how it sounds afterwards.
TooHype
Go Hard or Go Home !!
posted May 03, 2009 02:50 PM
zixxer14
Damn that was Quick
posted May 03, 2009 09:10 PM
Yea, speed tuning works great!
pissear
Professional Cockis Slap Peer
posted May 04, 2009 06:26 AM
Drop the oil sump pan or cut the oil filter open. I used to remove the oil filter cartridge from the engine, take a peek, screw it back on; no crank/rod bearing material is go out and beat it hard; she will last the race. Bottom line: Look for material.
creepdog
posted May 04, 2009 07:58 AM
will do.thanks
Smooth_G
posted May 04, 2009 08:48 AM
dubious,,, lyle,,does it get constant oil pressure to the rods ,,or is it intermittent,,,is there an annular passage cut in the middle of the main bearing on both halves ,or just one half,,,or does the crank have a groove in the middle of the main bearing area going the whole circumference
posted May 04, 2009 11:55 AM
There are 5 mains, the middle and 2 outer are not annular, and the other 2 between the 3 are annular. so it goes :
1 -no groove,
2 grooved,
3 no groove
4 grooved
5 no groove
The rods are not grooved
Smooth_G
posted May 04, 2009 01:17 PM
lyle,, thanx for the info,, some of the jap 4s have or had a annular groove only on the top main bearing shell to feed the rods,,the lower bearing shell had no groove,,so when the crank turns it covers the oil hole n has no oil pressure during that part of the stroke,,is the 14 that way??,,,,the best way to do it,,,is to pump the oil through both ends of the crank to all bearings,,it doesnt fight centrifugal force to get into the crank,,,the centrifugal force works in its favor rather then against it,,n a dry sump would rid the low oil pan,,the oil tank always has gravity pressure pushing oil to the pump,,no matter how far u lean it,,or wheelie,,oil is constant,,,plus u wouldnt have any problems with over filling or oil blowing out the breather
0.21520090103149 seconds processing time
