BIKELAND > FORUMS > ZX-14.com > Thread: new wheelbase ? NEW TOPIC NEW POLL POST REPLY
eb2318
zx14
posted May 02, 2009 02:19 PM
new wheelbase ?
just moved my wheelbase from 63' to 65' 1/2 will this help me with me 60 or 330 trying to get the gas open faster already gettin 1.52, 60 and 4.03 330. just wanted to see what you guys think?
i luv my zx14
01smokes
posted May 02, 2009 03:00 PM
it should if your track will hold you
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted May 02, 2009 03:21 PM
If it were me, I would have went farther back. I went 9" over stock and got my 60ft down to 1.42's and I weigh close to 230 suited
eb2318
zx14
posted May 02, 2009 03:55 PM
the track conditions are pretty good, that nice eklipse636 im about 200 suited and im would love an 1.42 60 how's your ets now?
i luv my zx14
posted May 02, 2009 04:58 PM
.. they WERE 5.85 1/8 mile and 9.15 1/4 milw foot shifting, but i never got a good pass not in 90deg weather while air shifter worked. but did 9.20's consistant all day
eb2318
zx14
posted May 02, 2009 05:44 PM
what are you staging at, track is in the morning just finished preping my bike
i luv my zx14
ninjaboy311
posted May 03, 2009 08:44 PM
I am at 69" with a best of 1.33 60' stock engine with good cool weather. Average 1.39-1.41 in the heat, 205 lbs suited.
If your track holds it, suspension/gearing is set up right, and have a sticky rear tire (Michelin,Shinko U-soft, Micky Thompson), your 60' will come down.
FastestBusaAround
I eat Fish...
posted May 03, 2009 08:58 PM
How do you guys deal with the extra wheel spin you get with the extended swingarm? I can't get this thing to stop spinning in the streets in 1st and 2nd. I'm running 6" over and 16/43's. I weigh 225. The bike can't leave in a straight line from 0 or any speed in 1st without major wheel spin, no matter what the temps are.
FYYFF!!!
01smokes
posted May 03, 2009 10:20 PM
try about 12 psi in a shinko and it should stick, also riding on the street is alot different than the track, on the street you HAVE to fineness the clutch a little more to not shock the tire to bad on the track you can toss the clutch IF the track is prepped right
ninjaboy311
posted May 03, 2009 10:40 PM
Also, if you know you are going to be spinning on the street, for those of you street racing with an air shifter, DO NOT try to shift the bike while spinning. You will likely bend a shif fork or tear up other sh*t in your tranny.
Extended wheelbases are not good for hooking on the street. But if you must do it, try a Shinko slick...they stick to anything.
posted May 04, 2009 04:44 AM
good info! i only ran a air shifter a couple of races, and luckily it was never spinning when i shifted.
eb2318
zx14
posted May 04, 2009 04:49 AM
ninjaboy you stated that if your suspension and gearing is right, any suggestions? i just moved back to 65', 16/43 u-soft shinko, thinking of going to a 44 tooth rear, only had 16 passes on my 14 gettin 1.52 60'. i only race at the track
i luv my zx14
ninjaboy311
posted May 04, 2009 02:16 PM
16-43 is good, I am 16-44, but with my wheelbase, I don't worry wheelies. At your wheelbase, you will wheelie if you use a 44, unless you ride the heck out of the clutch.
What is your weight, you may need upgrade your shock, or tighten up your existing shock so that you don't bottom out.
Keep practicing!!
eb2318
zx14
posted May 04, 2009 03:29 PM
im 200 suited. my bike really hasn't been et at all just put a good no flies map in and she really feels different. a guy at the track told me my bike looked out of balance, he said that i had my back too low no room for it to squat. but I thought the lower you are the harder you can launch your bike.
i luv my zx14
eb2318
zx14
posted May 04, 2009 03:33 PM
I have the 3 hole lowering links and its in the bottom hole. when i pull the strap the front looks lower than the back to me. but im just a starting out raceing at the track
i luv my zx14
ninjaboy311
posted May 04, 2009 05:19 PM
Yes the lower the better, but make sure you aren't bottoming out your undertail.
Got any pics?
eb2318
zx14
posted May 04, 2009 05:26 PM
test & tune wed. night will take pic then and going to get a vid too
i luv my zx14
0.23996996879578 seconds processing time
