BIKELAND > FORUMS > ZX-14.com > Thread: And for my next trick... ZX14 Billet Fuel rail NEW TOPIC NEW POLL POST REPLY
Compton
posted April 23, 2009 10:10 PM
Billet Fuel rail. -6 an In and -6 an Out. Can plug one side if you don't want to run a return system. black anodize finish.
yum.
b.w.
posted April 24, 2009 06:25 AM
Very nice!
Are you selleing them?
How much?
Hawkman
posted April 24, 2009 07:44 AM
Excuse my ignorance. What exactly does a fuel rail do? Benefits?
Compton
posted April 24, 2009 08:10 AM        Edited By: Compton on 24 Apr 2009 16:11
yes, for sale
200.00
This fuel rail will provide higher volume of fuel to the injectors and allow for a return style system if you choose on adding an external pump.
Higher HP bikes will be best off with this. I believe its a better solution then added fittings to the stock rail.
Plus they just loook so nice.
b.w.
WindSwordNinja
posted April 24, 2009 08:34 AM
Very nice Compton!
I know how FI works however I'm missing how the fuel leaves your rail and connects to the injectors.
Can you post a picture of the connectors and the rail by itself?
It may be obvious and I'm just not seeing it, if so excuse my ignorance as well.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
extrapilot
2008 ZX14
posted April 24, 2009 08:37 AM
You are such the handy one, I must say so.
'pilot
Compton
posted April 24, 2009 08:38 AM
Here is a pic of the mount that i used, and you can see the injector in the hole in the bottom.
b.w.
extrapilot
2008 ZX14
posted April 24, 2009 08:40 AM
Since I'm looking at throttle bodies, has anyone used Factory Pro's Velocity stacks?
Are they worth the asking price?
'pilot
Compton
posted April 24, 2009 10:46 PM
b.w.
thutch26
thutch26
posted April 25, 2009 02:09 AM
i see your right up the road from me Compton... quick question though???
How do you go about connecting this to your stock fuel pump with a crushed regulator?
Compton
posted April 25, 2009 07:19 AM        Edited By: Compton on 25 Apr 2009 15:19
safest way would be a welded -6 bung on the stock pump housing outlet. they are around 8 dollars. run a -6an line up to the rail, and dead head it by putting a -6an o ring plug on one side.
or you could do pushlok hose, clamped to the stock pump housing outlet, up the rail. and plug off one side with the -6an plug.
b.w.
Compton
posted April 25, 2009 12:41 PM
Check out my group buy in the backyard garage!
b.w.
frEEk
Group buy is here: http://www.bikeland.org/board/viewthread.php?FID=16&TID=46694
Zedexdragon
posted August 13, 2009 10:44 AM
So help me out here, how would this install on just an everday bike? It looks so dayam sexy and I like to tinker with crap, I feel I much have one!!!! Is this a direct bolt in to replace my existing one?
Cheers
Kinley
JR
drag racing
posted August 13, 2009 11:31 AM
look nice i was wondering if it was good to up grade to a better fuel rail
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
zx14turbo
truth....thats all i ask
posted August 17, 2009 05:33 PM
rail looks like a trick piece. if someone wanted to change injector size are there any that are stock size that are 4-600cc that will work or are on the market for your rail? thanks in advance.
zx14turbo
Compton
posted August 17, 2009 05:37 PM
Cheers
Kinley
I have a fitting for the stock pump housing and a line. You would just run the rail without a return for 100% bolt in.
b.w.
Compton
posted August 17, 2009 05:38 PM
i'm working on that right now. i have a good injector lined up that i'm doing some testing with. 440 cc to 700 cc range.
b.w.
Fastest-14
Fastest -14
posted October 04, 2009 08:00 PM
Compton, with this aftermarket fuel rail, what kind of performance gains can one expect from just this mod alone and is an after market, higher flowing fuel regulator and fuel pump a requirement with this rail?
Compton
posted October 05, 2009 03:02 AM
alone by its self you wont see any gain. its made for bike that need a larger fuel system.
depending on your application, but yes a adjustable fuel pressure regulator and a large pump, either intank or external would be needed too.
b.w.
Fastest-14
Fastest -14
posted October 05, 2009 04:23 AM
So you're saying that with more fuel being provided to the engine, there is nothing to be gained from it, (HP) etc with a custom map to make there is more air to accomodate increased fuel?
Would a 1417 or 1450, etc benefit from this fuel rail or would one be necessary for that size engine?
gilberjj
Friend of Fast
posted October 05, 2009 09:34 PM
a fuel system doesn't "MAKE" you more horsepower. it simply allows your engine to make more horsepower by providing the fuel. If you are making a lot of horsepower (or just using more fuel by switching to e85), you'll need an upgraded fuel system to supply the extra fuel. So, your fuel pump will need to supply more fuel, you'll need larger injectors to supply the fuel to the cylinders, larger lines perhaps for increased flow, and maybe a larger fuel rail as well. This one is nice because it already has a fitting so you don't need to tap the fuel system if you want to run wet nitrous.
Compton
posted October 06, 2009 03:05 AM
correct, this just makes things easier and looks nicer when adding a return line to the fuel system, perfect for boosted apps that want to run a rising rate regulator, or big motor or spray bikes that want a good bump in fuel pressure by using a 1.1 regulator instead of doing guess work with crushing the internal regulator
b.w.
bigwil
06 zx 14 turbo stage 3
posted October 06, 2009 10:20 AM
Brian any luck on the fuel rails for the bigger injecters i whant to put on the 750 injecters
thanks will
bigwil// going fast aint easy so turbo it
0.25209403038025 seconds processing time
