BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 2009 is 81 lbs more than ZX14 2008 NEW TOPIC NEW POLL POST REPLY
jerchung
posted April 22, 2009 04:28 PM
Anyone knows what's the difference the weight (81 lbs) has brought to the 2009 over the 2008?
14Monster
posted April 22, 2009 04:38 PM        Edited By: 14Monster on 23 Apr 2009 00:39
Where did those #'s come from? I would venture to say it was a dealer trying to get rid of a dusty 08.......
NoFault
posted April 22, 2009 04:42 PM
yea I would have to agree..
The ones I care to acknowledge;
2008 ZX14 (as of Feb 07/09)
2002 Roadstar Warrior
1999 Yamaha R1 (You are Missed)
1996 ZX7R
1989 Honda Hurricane (Rem those)
WARBIRD
posted April 22, 2009 04:47 PM
They are all more or less the same...........................06-09............
I'd Rather Be Roadracing.
extrapilot
2008 ZX14
posted April 22, 2009 04:49 PM
08 and 09 are only 11 lbs more than gen 1 as far I know. They added a cat at the back of the header pipe.
'pilot
extrapilot
2008 ZX14
posted April 22, 2009 04:52 PM
The ZZR1400 maybe more, I think they come with the center stand as standard equipment and they have a rear grab handle which has heavier hardware pieces to them.
'pilot
posted April 22, 2009 05:40 PM
But 81lbs for a centerstand, grab handle, and a cat??? Wow, that must be some heavy metal...
Wheelie
Old Man
posted April 22, 2009 05:44 PM
maybe 8.1lbs
wee
Lucky14
posted April 22, 2009 05:49 PM        Edited By: Lucky14 on 23 Apr 2009 01:52
You're kidding, right?
Everyone knows that the added weight of the supercharger, brackets, and larger radiator brought the weight up significantly.
Either that, or the manufacturers are now reporting a realistic *curb* weight instead of the prior *dry* weight. Check any other model, including the Suzuki site and you will see that all the bikes, including 600's and literbikes, look to have gained a LOT of weight.
Wheelie
Old Man
posted April 22, 2009 05:51 PM
looks like 11 lbs dry.
wee
posted April 22, 2009 05:55 PM
81? come on now! surely ye jest!
gremlin
posted April 22, 2009 06:12 PM
The difference is the direct result of Japanese manufacturers deciding to classify bike weights differently bewteen the 08 and 09 model years. Here is the ZX14 weights taken directly from Kawasaki's 2008 and 2009 brochures:
2008 Dry Weight: 474 pounds
2009 Curb Weight: 566.7 pounds
The dry weight was always suspected to be far removed from reality. The actual weight gain from the 08 to 09 model is about 11 pounds. I own both 06 and 08 ZX14s in stock condition and can vouch for the 11 pound weight difference.
Looking at the Certificate of Origin for both bikes, the 06 ZX14 claims 190 horsepower, and the 08 ZX14 claims 193 horsepower. Strapped to a dyno, the 06 makes more peak power then the 08, with the 08 making significantly more low to mid-range power.
Manufacturer claims for weights and horsepower are nice referenced points, but reality (scales and dynos) usually tells a diferent story.
davej
posted April 22, 2009 10:36 PM
My 14 weighed in at 543 # with two gallons on fuel. Turbo. 2# more than stock. You need to get the 80 lb. Hooker off the bike. Or your in serious deep shit,. Chester.
Triumph guy
Bluebyyou
Gettin My Curve On
posted April 23, 2009 02:24 AM
Also, the euro version ZZR can be had with ABS brake systems which could add even more, maybe 20 lbs.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
stop2go41
posted April 23, 2009 06:17 AM
80 lbs just cant be right
extrapilot
2008 ZX14
posted April 23, 2009 09:10 AM
I think that jerchung is comparing the wet verses dry weight: 566-485=81lbs.
Curb weight is the same as wet weight.
'pilot
BIGZXDADDY
posted April 23, 2009 11:14 AM
as far as the centerstand is concerned it weighs as much as the belly wing and bracket that it replaces
"never drive faster than you can see, besides it's all in the reflexes"
jerchung
posted April 23, 2009 11:55 AM
Extrapilot, is it that a big differrence between wet weight vs dry weight? How much more weight does a full gas tank add to the bike? Maybe five lbs extra with a full gas tank. Could someone explain what are the additional items included when considered dry weight to wet weight? I think Gremlin had a relatively good explanation above. Thanks Gremlin.
BIGZXDADDY
posted April 23, 2009 12:15 PM        Edited By: BIGZXDADDY on 23 Apr 2009 20:15
it is exactly what it says, nothing liquid is included with dry weight. oil,antifreeze,fuel,brake fluid.etc. 8o lbs on something the size of a 14 would be about right with the extra cat
Hawkman
posted April 23, 2009 12:34 PM        Edited By: Hawkman on 23 Apr 2009 20:34
At 6lbs per gallon of gas, that makes the other 3.8 gallons = 22.8 lbs. Total is 565.8 lbs. Just like what Kawasaki states...pretty much.
posted April 23, 2009 12:45 PM
easy now, 80 pound wiminz on bikes is a good thing
Compton
posted April 23, 2009 01:37 PM
my bike was 520 with a half tank of gas.
b.w.
14nooby
posted April 23, 2009 03:57 PM
A full tank of gas 5 lbs??????????????????? On a kx 50
fast-14
posted April 23, 2009 04:03 PM
bone stock 08 (added hids, maybe 5 lbs)with full tank weighed 575 on cert scale
'08 sapphire blue zx 14
still have a learners permit..
KaiBosh
posted April 24, 2009 12:25 AM
It's true - they added another seven catalytic converters. There is also now a third set of butterflies, which you have to remove in order to remove the secondary butterflies. The new TRE isn't cheap, you can make one yourself with a seven billion ohm resistor.
0.27574706077576 seconds processing time
