BIKELAND > FORUMS > ZX-14.com > Thread: Brocks Track map No Filter NEW TOPIC NEW POLL POST REPLY
Stu64
posted April 21, 2009 06:10 PM
How many of you guys using Brocks exhaust are running no filter at the track?
Basically my bike is track only these days and i run a BMC race filter, i've had it in there for 2 seasons and only collected 2 bugs and no noticable dirt when i removed it this winter.
I bought a used sidewinder(brocks) and the maps call for no filter, i felt a little uneasy about running this way so i came up with a compromise.
I took my OEM filter off the shelf and removed all the pleats,then i took some aluminum window screen cut a little over size and folded in the sides and JB welded it to the filter frame,put a aluminum wire down the center for extra support.
This screen should catch all larger particles,bugs,little stones,etc.
Going to spray it with WD40 to catch as much dust as possible.
So what do you think? Better than no filter?
posted April 21, 2009 06:12 PM        Edited By: Shane661 on 22 Apr 2009 02:13
I like it!
Btw, I'm installing an 08 fuel pump on mine tomorrow...
Stu64
posted April 21, 2009 06:30 PM
I have taken a zx6r fuel pump housing and put the 08 internals in it. The 600 fuel barb on the bottom is about 1/2" shorter than the 08 zx14.
Can't tell how it works yet(not driven yet) but the bike does run with no noticable difference.
TooHype
Go Hard or Go Home !!
posted April 21, 2009 10:25 PM
I like it!
+1
NinjaNick
'08 ZX14 (Blue)
posted April 22, 2009 04:21 AM
Good idea!
reevesmreeves
posted April 23, 2009 06:26 AM
that's because everything else went into your motor.
06 red 14
06 se 636
posted April 23, 2009 09:19 AM
gilberjj
Friend of Fast
posted April 23, 2009 09:24 AM
your motor said: num num num num
Stu64
posted April 23, 2009 03:30 PM
Is that your wife?
Stu64
posted April 23, 2009 03:31 PM
Yeah, sure it did,what filter are you running?
0.22262001037598 seconds processing time
