BIKELAND > FORUMS > ZX-14.com > Thread: Problem CO2 Refill NEW TOPIC NEW POLL POST REPLY
KSPZ3
posted April 21, 2009 10:02 AM
Problem CO2 Refill
I have a co2 shifter. I just bought a new nitrous bottle with a vavle on top with a dash 4 female threaded connector. I have gone to a number of places to try to get it filled including welding supply and local sporting stores that refill paintball equipment. None seem to have an adapter to get it to work. Does anyone know how to get these things filled with CO2. Are there some commonly used adapters? Neither Schnitz nor MPS were able to help me out on this one....
Thanks,
Kevin
posted April 21, 2009 11:05 AM
Put N20 in it like all the rest of us do ...
KSPZ3
posted April 21, 2009 12:13 PM
Smokin - Does N2O work as well as CO2 - a bit more expensive? Do you do N2O even if you are not running Nos as power adder?
Thanks,
Kevin
Wheelie
Old Man
posted April 21, 2009 12:18 PM
cost $4 a pound around here
wee
KSPZ3
posted April 21, 2009 12:38 PM
I just got quoted $15 to fill a one pound bottle...... Yikes - must find alternate source.
Wheelie
Old Man
posted April 21, 2009 12:40 PM
all of the tracks have it in the D/FW area.
wee
posted April 21, 2009 04:52 PM
3 bucks a pound here .... It's cleaner than co2 .. The only thing i use it for is my air shifter ..
zxbob
posted April 21, 2009 05:16 PM
I went to a welding supply and bought a 25lb bottle of 02 . I think it cost me $85.00,
First time expence, easy fill ups afterwards ..... sell it to your fiends !
Bob
Silver08
posted April 21, 2009 05:22 PM
http://www.mpsracing.com/products/MPS/as07.asp
dont know why MPS couldnt help
you can use the pin valve adapter (1-0340) and the valve pictured in 1-0329 and 1-0377. also, your local hydraulic/hose store (check phone book) could probably make you an adapter with -4female to a paintball thread pin valve.
08 ZX14
kawasakijockey
posted April 21, 2009 05:26 PM
If you buy a 10lb. nitrous bottle,used, and get it filled you can freeze the 1 lb and fill it from the 10lb. I have been doing this for a year now. Nobody here fills 1lb bottles.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
KSPZ3
posted April 21, 2009 05:57 PM
I like the nitros idea and I will look into it. I did get it filled tonight - Here is the trick - If you have them remove the pin vavle adapter there is a fitting on the hose that will screw into the bottle after you remove the bottle fitting - so you need to take a cresent wrench to the store - had it done at a local Dunhams Sports - $4.00. Now if I start filling the bottle with Nos - the next thing will be putting a dry set-up on it....
Thanks for the help and advice.
Kevin
0.20959997177124 seconds processing time
