Niner9
posted April 15, 2009 02:58 PM
air cleaner and throttle bodies
hey guys, just stripping the bike down for its valve adjustment tomorrow at shop, I have a BMC filter in her and not happy with all the debris I found that got passed filter. Also there seems to be oil a top and around the throttle bodies? is this normal? Bike has 22k kilometres, (13750 miles,) It's an 06 model, have read some threads bout the air filter element not sealing properly.
TIA, Mark
Akro slip ons, Scotts Damper, Hel Brake & Clutch lines, Vortex Rearsets, Sato Frame Sliders, Power Commander, Custom Map, Flies Removed, BMC Race Filter, Marchenisi Rims, Corbin Seat, Ventura Pack Rack, Pazzo Levers, Zumo 550 GPS, Passport Radar Detector, Throttle Miester Cruise,
Bluebyyou
Gettin My Curve On
posted April 15, 2009 03:22 PM
It's not so much your filter as the warped black plastic cover air leak. On a tip I ordered an aluminum cover for an 09 to replace my stock black plastic cover. Mine is a 2007 with 15500 miles and runs a BMC race filter. I had read complaints about this dirt past the filter issue before and watched for it. I have pulled it down several times to check for grit past the filter, found virtually none.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
Douglas Home
posted April 16, 2009 05:10 AM
Schnitz racing has an aluminiun air filter cover that seals better , I think its about $29US .
Doug Mackay Australia
Niner9
posted April 16, 2009 06:51 AM
thanks guys, what about the light film of oil????
Sticks_n_Stones
posted April 16, 2009 07:11 AM
Normal. There is a way to fix it from happening again, but I forgot. Check out Shanes build thread, I'm sure he covers it in there. One thing that does help, is never run your oil higher than half way up your sight glass (when warm).
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Niner9
posted April 16, 2009 07:42 AM
one more question, if you look dead centre of pic there is a threaded hole, is there supposed to be a bolt in there?????
http://farm4.static.flickr.com/3564/3447907034_35c6a65114_b.jpg
WindSwordNinja
posted April 16, 2009 08:11 AM
Assist
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
Niner9
posted April 16, 2009 08:24 AM
thanks Wind
Douglas Home
posted April 16, 2009 09:08 AM
Mine didnt have one in it , which was great as I bolted my nitrous solenoid there!
Douglas Home
posted April 16, 2009 09:56 AM
is your filter a BMC race or street ? Id use the street filter if you have any dust worries .
While your tanks off it could be a good time to check the battery terminals , as some on here have had them loose .
Niner9
posted April 16, 2009 10:33 AM
cheers guys, not sure if I have race or street BMC, will have to check, it was completely plugged with bugs!!!!! And glad to hear bolt is not missing!
Niner9
posted April 17, 2009 03:25 PM
f$$k, bike was in today for service and they were doing the frame recall at same time, engine has to come out due to over torqued mounts, hope frame is okay!!!!!!!!!!!
