BIKELAND > FORUMS > ZX-14.com > Thread: Has anyone had a timing chain break NEW TOPIC NEW POLL POST REPLY
serius blk
posted April 14, 2009 09:45 AM
Got on it in first. Tire spun alittle and the motor shut off. Error code 23 came up on the display. Starter would turn but nothing else. Got back home and pulled it down. Timing chain stuck in the valve cover. Pulled the plugs and they are in good shape. Im going to pull the head to make sure nothing else happen. Thinking of going with a manual chain tensioner next time. Does anyone know how to set those. How tight.
ZX11D
Internet Police
posted April 14, 2009 11:54 AM
How many miles you have on it? Any mods? Oil used?
'94 ZX-11
'07 ZX-14
serius blk
posted April 14, 2009 11:58 AM
9000 20-50 lucas motocycle racing oil. alien head, gearing, power commander, speedohealer. Stock motor other than that.
pissear
Professional Cockis Slap Peer
posted April 14, 2009 12:45 PM
My guess was cam or crank so crank moves, code 23 sits in the head and defaults = Cam Sensor is out of phase/wave goodbye to the valves.
1. WOT year?
2. How many miles?
3. Ever change the cam shims?
davej
posted April 14, 2009 07:59 PM
20/50 oil will take longer to build the pressure needed to tension the chain. Your cam chain buckled most likely. Going back to syn oil 10-40 Mobil. Kaw oil seems to break down early. Heavy oil. Never will go the heavy is better route. Harley used to sell 60 w and 50 for summer, Bad move.
Triumph guy
blackbullet76
posted April 14, 2009 10:03 PM
I'm thinkin of goin with synthetic on my next oil change. My timing chain tends to make more noise on start-ups.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
pissear
posted April 15, 2009 03:59 AM        Edited By: pissear on 15 Apr 2009 12:00
Pg. 114 of your Owner's Manual; shows a 20/50window and 10/50w is thinner still and is within range of any weights and measures. That means you are good to go is pick the ambient and now choose the weight to match the heat of the temp bar at the bottom.
Something called the weakest link could be one. Maybe something flew under the chain; whipped it did it up the chain along for the ride; found it's way under the chain and "Ding" goes any link is now a dingle berry stuck there is yes, I am thinking out of my ass but not oil as the; Cause > I think you might look elsewear; like who else took a shit in the case to do that as to break a chain? Scare me and say it is together and I stop riding this bike.
How tight? YOu could not give me a tensioner recall I am off this bike period! Is the chain in one continuous link like a wrist band for the green giant or is it broken and looks like a snake you hold it up?
kawpower
Mr kawasaki 2 you!
posted April 15, 2009 04:19 AM
SNAPPED 1 LAST YEAR.06zx14
kawpower
Mr kawasaki 2 you!
4000 miles
pissear
posted April 15, 2009 06:37 AM
Are they buying chinese chains as their jobber for cam chains?
serius blk
posted April 15, 2009 09:06 AM
yes kawpower mine is a 06 also 9000 miles. I just hope it didnt do any damage to anything else.
davej
posted April 15, 2009 06:19 PM
What shop manual are you looking at? I have the 2007.
Triumph guy
pissear
posted April 15, 2009 08:58 PM
Owner's Manual, my good man, not "Shop Man" You Will... See it on pg 113 or 114 depending on year of manual that came with your bike.
kawpower
Mr kawasaki 2 you!
posted April 16, 2009 05:05 AM
if the chain broke u more than likely bent some valves,change over to the zx12r stock adjuster and have fun.
posted April 16, 2009 02:24 PM
stock cams?
stock rpm limiter?
serius blk
posted April 17, 2009 04:37 AM
yes stock everything
posted April 17, 2009 06:37 AM
tensioner / oil pressure failure.... not good.
0.29606103897095 seconds processing time
