BIKELAND > FORUMS > ZX-14.com > Thread: adding fuel for dry shot NEW TOPIC NEW POLL POST REPLY
specialzx14
posted April 13, 2009 04:59 PM
hey i have an 07 with stock filter m4 slip ons flies out and a spray bar im running a 30 shot, i have a motor map the one dynojet has for filter and slip ons, i had 30% fuel added on top but it ran slower spraying than it did on motor with the spray bar i ran 6.20s with it just spraying in the air box i ran 6.0s is it my map or what the bar seems to make it slower i need help please until i can afford to get it tuned
kawasakijockey
posted April 13, 2009 05:03 PM
That is way too much fuel. 10-15% is what a 30 shot calls for.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
specialzx14
posted April 13, 2009 05:45 PM
so i just need to put like 13 extra on say 5000rpms and up?
kawasakijockey
posted April 13, 2009 06:01 PM
My opinion would be to spray at 7000 up.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
specialzx14
posted April 13, 2009 06:11 PM
its set on wot i just didnt know where to start adding the fuel in the map
specialzx14
posted April 13, 2009 06:15 PM
and say at wot the power commander number is -3 so if i add 13 to it it should be -16 correct? or if its -9 it should be put on -22?
kingtramp
posted April 13, 2009 06:41 PM
Just use face plate hi side button, add 6%
specialzx14
posted April 13, 2009 06:45 PM
add 6% i understand using the face plate but adding only 6%
specialzx14
posted April 13, 2009 06:46 PM
im lost
06redzx14
posted April 13, 2009 06:56 PM
if you're adding 13% if it's at -3 you should put a 10 if -4 it would b 9 and so on
NINJA12
posted April 14, 2009 06:17 AM        Edited By: NINJA12 on 14 Apr 2009 14:19
negative are like bills and positives are like you paychecks.
If you have more bills (neg) add them together for total bills(big neg).
If you get more checks subtract the bill to make them smaller (smaller neg) or figure how much of your check is yours (pos).
Thats the example I like the most. Most people can relate to money.
you case -3 (bills) plus +13 (check) you have +10(pos) .
The sign of the answer always goes with the bigger number. (13 is bigger than 3).
I use to teach math in a previous life and that brought back memories.
0.28828597068787 seconds processing time
