BIKELAND > FORUMS > ZX-14.com > Thread: 14 crankcase pressure? NEW TOPIC NEW POLL POST REPLY
duncan
posted April 12, 2009 04:35 AM
Like alot of peoples turbos my buddies turbo 14 is coating the rear of his bike with a little oil...Does the 14 create a little more pressure than say a busas crank? My turbo busa doesn't push a drop of oil...I've told him to either cut a couple of inches off his oil line or take it off all together, but he's not wanting to...Any other suggestions?
zxbob
posted April 12, 2009 04:41 AM        Edited By: zxbob on 12 Apr 2009 12:42
If there's puking oil ..... there is a problem with the motor !
On my 14 I added an addition vent, but never had any oil puking out the back ........
nor does the new owner !
Bob
posted April 12, 2009 04:55 AM
Our Busa is sensitive to oil level....I keep it in the center of the window (we also have a billet pan). If I top it off, it will spew some under boost...
davej
posted April 12, 2009 03:51 PM
Had that problem with my turbo and was just too high on level. Middle of the window is good, top line and it may puke. Only running 5# boost. Put a catch bottle on the breather.
Triumph guy
JDC
posted April 12, 2009 05:00 PM
I had a lot of oil coming out, kept it at mid level in the window 7 PSI. Removed the crank case vent internal hose, and no more.
0.25050091743469 seconds processing time
