BIKELAND > FORUMS > ZX-14.com > Thread: Cam chain adjuster NEW TOPIC NEW POLL POST REPLY
davej
posted April 10, 2009 04:45 PM        Edited By: davej on 11 Apr 2009 03:57
Cam chain adjuster
I have 27K now and it takes 2 restarts to reset the auto adj. What are the problems with going to a manual bolt replacement? Do you set it warm or cold or does it cause problems set cold too tight and hot too loose? Looked up the past threads but no mention of hot or cold adj.
Triumph guy
pissear
Professional Cockis Slap Peer
posted April 11, 2009 06:05 AM
Cold set. The best way is to take so much slack out of the chain. The trick is not to burn the slipper because you wanted zero movement out of the chain, you load the slipper too hard. The chain accelerates the wear. The automatic moves when the chain wears or the slipper wears a groove in it.
You are now a constant adjuster or else you will not know how sloppy that chain and sipper tend to get if you do not stay on top of it like the automatic adjuster with oil assist to lock the tension down under fluid, not static like you are about to zipper the slipper is take a pee is as much maintenance almost.
blackbullet76
posted April 11, 2009 06:44 AM
I had one on my 01 zx6r and I checked adjustment after every other ride. It was easy to get to though, no fairing removal.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted April 11, 2009 06:58 AM
stick with the stocker
Old Guy
posted April 11, 2009 09:17 AM
I got a A.P.E. manual. They are a hassle cuz you have to at least pull the foreman grill to get at it. And then you dont have a real good feel on the tension being applied to the adjustment bolt.
Like pissear says, you now have to be the adjuster all the time.
Maybe pull your stocker and check for wear and/or other problems.
i'm thinking about putting the stocker back on.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
zxbob
posted April 12, 2009 04:46 AM
I put the APE tensioner on my bike .... they need adjustment as often as the valves do !
I was 8K plus miles and it was still fine. If you install / adjust properly, they are set it and foget it !
Bob
0.24879789352417 seconds processing time
