BIKELAND > FORUMS > ZX-14.com > Thread: DigiKill3 plus autoshift? NEW TOPIC NEW POLL POST REPLY
Silver08
posted April 06, 2009 05:47 PM
is anyone using autoshift with their muzzy shifter or digi Kill3? I am trying to use the multi-hub to make mine autoshift, but having some difficulty.
looking at shift minder, MPS auto box, etc. if i cant get the hub to work.
08 ZX14
northernkaw
posted April 06, 2009 06:12 PM
I did and had some problems.watch what you set the shift point at the rev limiter is lower then the tach redline.10800rpm is the limiter. I found that you have to go almost the max for kill time.is the hub not killing at all ? set the shift at 3000 and check the circut with a light . check to make sure you want the digi to see a ground to activate.
Silver08
posted April 06, 2009 06:51 PM
I dont want to increase my kill time.
it will shift now from 2nd to 3rd and to 4th but no 1st-2nd. I am trying something tomorrow. I just cant afford a missed shift on nitrous. wondering which of the autoshifts out there people have successfully used with the digikill
08 ZX14
Silver08
posted April 06, 2009 06:52 PM
shifts every time using the horn button.
all the hub has to do is send a ground! others are having problems with the relay output on the hub, so i dont know
08 ZX14
posted April 06, 2009 07:12 PM
You are using the hub output to activate a relay, so the digikill see's ground when the relay is activated right?
I did not use the hub for auto shift.
DJ told me I had to use the relay output to activate a 12 v automotive relay, I used the relay to activate the second map for nitrous.
All I know is the relay output on the hub doesn't supply 12 volts, and can't handle any amperage.
Also might add, I had to increase kill for 1st to 2nd shift.
I was able to run 0ms with the air solenoid on the ram, and 30 ms kill, except the 1st to second shift required 40ms.
Silver08
posted April 06, 2009 07:35 PM
I have a the relay output wire going through a relay to make a ground activation. Its sending a ground, because it works in the upper gears. I have my delay set to 0, solenoid on the ram, and the kill set to halfway(no numbers on the digi). If i have to increase my kill too much, I am going to try something else. 40ms is not that much though at all. is that with a digikill?
08 ZX14
posted April 06, 2009 07:42 PM        Edited By: dubious on 7 Apr 2009 03:43
yup, originally it was 40 ms delay, and 40 ms kill.
when I put the solenoid on the ram , i was able to do away with delay.
it was a digikill, bought it in 2006
BigJaay1
THUNDAKAT RACING
posted April 06, 2009 08:16 PM
I'm using the MPS autoshift box. 10800 chip. It's been on the bike since June 06. No problems. (lifetime warranty too)
Jay
2006 Kandy Brandywine / White Diamond ZX14 - HPC POWERED
Silver08
posted April 07, 2009 05:59 AM
are you using the MPS autoshift w/ kill, or just the auto box on top of another kind of kill?
08 ZX14
BigJaay1
THUNDAKAT RACING
posted April 07, 2009 07:19 AM
The MPS autoshift box with kill.
BigJaay1
THUNDAKAT RACING
posted April 07, 2009 07:29 AM
The only thing to keep in mind with the MPS-Auto, is it is a pretty big box. I had to cut the underside of my seat for it to fit.
Jay
Silver08
posted April 07, 2009 08:09 AM
i wonder if i use just the autoshift without kill, on my digikill if it will work?
nice lookin bike bigjaay
08 ZX14
BigJaay1
THUNDAKAT RACING
posted April 08, 2009 04:30 AM
Thanks................. I guess that would work. But with space being an issue, I would prefer to have both functions in one unit. Plus, they would both be covered under the lifetime warranty.
Jay
0.38832306861877 seconds processing time
