BIKELAND > FORUMS > ZX-14.com > Thread: ping smokinzx14 NEW TOPIC NEW POLL POST REPLY
fury
posted April 05, 2009 12:39 PM
ping smokinzx14
air shifter leaking NOS.
I was told there is a rubber o ring to lube.
Where do I find this piece on the block?
Do I need to take anything apart or just shoot lube in the vent?
Thank you.
posted April 05, 2009 01:24 PM
You can just pull the in line off and shoot a little WD40 in there ...If that doesn't fix it you will have to pull the valve apart and replace the rubber on the plunger .... Or buy a new switching Valve ... You can get a new Valve from Granger real cheap if needed ... Granger may even have a kit to rebuild yours .. http://www.grainger.com/Grainger/wwg/start.shtml
P/S don't leave your bottle on when not in use , over time this will kill the valve if left on ..
fury
posted April 05, 2009 01:54 PM        Edited By: fury on 6 Apr 2009 00:43
Thank you...
Check out the Max thread.
0.40412306785583 seconds processing time
