BIKELAND > FORUMS > ZX-14.com > Thread: muzzy airshifter NEW TOPIC NEW POLL POST REPLY
jdrill04
posted April 05, 2009 03:58 AM
muzzy airshifter
I am removing a muzzy airshifter from my 06 zx-14. This was installed at the dealership when i bought the bike. Need instructions, or someone to tell me witch wires I have to put back after removing the plug and play harness.
kawasakijockey
posted April 05, 2009 07:08 AM
If it is like the Muzzy I have start on the right hand side controls. Under the rt dash cover is the wiring harness coming from the thumb switches. At the harness plug connection should be a red Muzzy wire tapped into a black wire on the start button circuit, remove the red wire. There is a blue/white wire connected to a blue Muzzy wire with shrink tubing on the connection. Cut the shrink tubing off and unplug that junction. There is a black Muzzy wire installed into the bike's factory plastic plug, remove it and install the blue/white wire back into the plastic plug. You are done on the right side.
Under the left cover is the horn button harness connection where there is a black/white wire from the horn button connected to the airshift toggle switch, pull the wire from its connection. There is purple Muzzy wire from the toggle switch going to the harness connector, remove the purple wire and install the black/white wire here. That should be it if you have all of the same wire colors that I have.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
mokaw
posted April 05, 2009 01:42 PM
If you need instructions I can mail you mine, if you mail them back when done.
Every knee shall bow, every tongue confess that Jesus is Lord!
jdrill04
posted April 05, 2009 07:29 PM
T hanks guys. Kawasakijokey Thanks for the input. the wires were a little different colors. But your info helped I got unhooked
Bawls
re-learning to ride
posted April 05, 2009 07:51 PM
now you need to give it to me so that it's not laying around your garage taking up space
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
jdrill04
posted April 06, 2009 05:32 AM
I would but i let one of the guys i ride with around here put it on his bike.
jarhead
posted April 06, 2009 03:33 PM
Whats up J? I thought you were still in the process of adding to your bike. We need you keep them Busa's in check down there.
jdrill04
posted April 06, 2009 05:40 PM
I changed to the mps auto shifter, you know grudge racing you dont have any rules just get it done. how is it going earl?
jarhead
posted April 06, 2009 06:08 PM
I am well, looking to do some racing this year. We still have snow up here so I am getting a bit anxious. Stay in touch, be careful, and good luck.
0.24596905708313 seconds processing time
