BIKELAND > FORUMS > ZX-14.com > Thread: Smoooooth...... NEW TOPIC NEW POLL POST REPLY
Acat
posted April 02, 2009 02:12 PM
Smoooooth......
Looking to make bike as smooth as possible. I have 07 w/flies out ,PC,Stock exhaust,did TBS, Amsoil,Dyna Beads,10 fender,Tobin seat. What next? I would like to try a Gipro and or an advance plate. Not wanting more power just smoothness.
posted April 02, 2009 02:16 PM
Perhaps synchronizing the throttle bodies? Maybe some heavier end weights to minimize bar vibration? A different windscreen to quiet the wind blast?
posted April 02, 2009 04:32 PM
I thought the 14 was a smooth riding bike..
Wheelie
Old Man
posted April 02, 2009 04:47 PM
put the secondaries back in
wee
Acat
posted April 02, 2009 05:52 PM
6th gear is smoother than the rest. TRE should change this? Just trying to get the last little bit of the I-4 BUZZ out.
heraser
Tall Blue 14
posted April 02, 2009 05:53 PM
wee
??? MIne is definitely smoother with the flys out. Plus I have Ivan's map and what's in my signature. Just got the new upgraded Ivan map which is unbelievable! FASTER AND SMOOTHER.
Blue '07 Racetech Fork Kit/Ohlins Rear
Ivan Tuned Fast and SMOOTH!
  Ignore this member    Click here to visit heraser's homepage.
posted April 02, 2009 06:02 PM
whats this "smooth" phenomenon all about
Wheelie
Old Man
posted April 02, 2009 06:14 PM
get a Gold Wing.
wee
Acat
posted April 02, 2009 06:52 PM
can you Send me that map?
Bawls
re-learning to ride
posted April 02, 2009 08:08 PM
try getting some Johar grooved extra thick foam grips. They're tasty lol
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted April 03, 2009 02:35 PM
run motul 300v full syn15w50 with a new set of plugs if you want to feel smooth
posted April 03, 2009 05:30 PM
Hell ride fishes Busa for 3 days and your zx14 will feel real smooth ...
posted April 03, 2009 06:15 PM
FastestBusaAround
I eat Fish...
posted April 03, 2009 07:01 PM
Buzz? Your Zx has Buzz? Bar end weights - ThrottleMeisters polished, I have ZERO buzz; never had on my 06 or 08.
FYYFF!!!
posted April 04, 2009 06:22 AM
pissear
Professional Cockis Slap Peer
posted April 04, 2009 06:37 AM
Last thing you want is a tre. That ruins the smooth but will set an annoying (((buzz))) to it. You need to be bone stock and that map has to be pouring smooth out the back end of the stock mufflers; or you will lag with the gas and there goes not only the crisp but the smooth remains smooth; but lags more in a lower fuel to air ratio number. Stock will smoke you, you are too fat at the map.
Sync is a given. Valve adjustments are a given before you start out "Smoothing."
You said smooth and that is where I am sending you, because you said, "Not wanting power but smooth me."
posted April 04, 2009 11:47 AM
hell send him to smoothville in a smoothmobile or smoothlimo
davisag
posted April 04, 2009 01:31 PM
hi
i tuned my engine with j&e high compression pistons, ported head, and carpenter cam, to make almost 210 at the wheel
made it smoother than stock by having the crank and rods balanced and retained balance shafts, and balancing the throttle bodies did make a difference as a couple of mine were out
posted April 04, 2009 02:06 PM
hi
bigdtd's friend strokerZX14 did some similar mods
Douglas Home
posted April 04, 2009 02:27 PM
Acat , what are dyna beads ? Never heard of them ,
Doug Mackay Australia
butta4hc
posted April 04, 2009 03:17 PM
Maybe a suspension upgrade? I love most everything about the 14 except for its spongy ass forks. I would love to have a revalve or some ohlins. I also like my stock seat but maybe Sargent seat can "smooth" things out. Get a steering damper possibly? Good tires and proper balancing is also critical for some "smoothness." Invest in yourself as well. If you got on a trashy helmet or improper riding gear that can make for a not so "smooth" ride. When I ride long distance I like to "streamline" myself by wearing a 1-peice. there is nothing worse than riding for miles on end with some big baggy ass flapping jeans or such. Make sure your chain is not snatchy and sagging. I'm just throwing random stuff out atcha if you can't tell, lol.
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
Acat
posted April 04, 2009 03:40 PM
Dyna Beads are tire balancing beads. About 1/16 in diameter. They " find " the light spot in the tire as you roll. Since I have polished my wheels I did not want to put the lead weights back on so I gave these a try. Seem to work ok. Hard to tell though but no complaints.Hub, I mean Pissear, why do TRE add vibes? Mapping to 6th gear which seems Smoooothest seems the right thing to do.
Douglas Home
posted April 04, 2009 04:57 PM
Thanks Acat , I wondered if they were like love beads to shove up the exhaust before my bike did a pole dance!!!
Bigbore4
posted April 04, 2009 09:55 PM
"Last thing you want is a tre. That ruins the smooth but will set an annoying (((buzz))) to it. You need to be bone stock and that map has to be pouring smooth out the back end of the stock mufflers; or you will lag with the gas and there goes not only the crisp but the smooth remains smooth; but lags more in a lower fuel to air ratio number. Stock will smoke you, you are too fat at the map.
way too much light in the place is shoot the lights out and make it really dark inn year ear is F YO and the bike you clanked in on. "
WTF????????????
Where did this come from? Mars?
pissear
posted April 05, 2009 02:20 AM
It comes from syncking your blades before you sync them. WTF you dowit your blades is your deal. Did you wet check them first before you sync them? I didn't think so.
0.25744009017944 seconds processing time
