BIKELAND > FORUMS > ZX-14.com > Thread: Brake rotors NEW TOPIC NEW POLL POST REPLY
Bluebyyou
Gettin My Curve On
posted March 22, 2009 03:10 PM
Brake rotors
I've read about warped rotors but never had one until now at 14.5 K. My 2007 bikes out of warranty, what should I get as a replacement, EBC?
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
extrapilot
2008 ZX14
posted March 22, 2009 03:23 PM
Check your pins on the rotors to make sure they are floating like they should. You should be able to walk the pins some from side to side, if not, they could feel like the rotors are warped.
'pilot
'pilot
Newf14
2007 ZX1400
posted March 22, 2009 03:56 PM
Where are these pins on the rotors I like to check mine, so if they are floating you should be able to move em a lil?If they cannot be moved is there a way to free em up?
Newf14
extrapilot
2008 ZX14
posted March 22, 2009 03:59 PM
It's the pins that hold the rotors to the carriers at the wheel hubs.
'pilot
'pilot
extrapilot
2008 ZX14
posted March 22, 2009 04:04 PM        Edited By: extrapilot on 23 Mar 2009 00:06
http://www.sonnyengineering.net/product31.html
The red thingies on the above linky
'pilot
'pilot
Bluebyyou
Gettin My Curve On
posted March 23, 2009 03:51 AM        Edited By: Bluebyyou on 23 Mar 2009 11:53
Hmmm. Thats interesting because it really feels more like a rapid pulse thru the lever than a warped rotor. If it is the rotor pins, what can I do about it? Replace 'em???
extrapilot
2008 ZX14
posted March 23, 2009 05:08 AM
Try cleaning them, using a parts cleaning fluid, the one that comes in a srpay can. That's the reason that the pins are there and must float around, so that is the rotors are slightly warped, the rider won't feel them. Not saying the rotors could not be warped, but worth a try.
'pilot
'pilot
Sticks_n_Stones
posted March 23, 2009 05:22 AM
He's right, heard it mentioned a few times in the past that the 'pins' caused it. One guy actually beat his with a sledge hammer and freed it (he had new ones on hand), and the other guy took his off, found it was straight after removal and put it back on with no problems.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted March 23, 2009 05:33 AM
Ouch
posted March 23, 2009 06:27 AM
its all good - use the right tool for the right job
INTIMIDA2OR
RED rider!
posted March 23, 2009 07:10 AM
Who says not to use a hammer on a motorcycle
'06 Passion Red ZX-14
*Lee*
extrapilot
2008 ZX14
posted March 23, 2009 08:42 AM
Bigger the Bike......Bigger the Hammer..
'pilot
Old Guy
posted March 23, 2009 10:32 AM
Use brake cleaner and compressed air.
Mine stopped feeling warped when I scrubbed the rotor faces with brake cleaner and green scrubber sponge.
Old nascar tip I picked up somewhere.
Uneven brake pad deposits from hitting hot brakes hard at track days made the rotors feel warped on next street ride.
Didnt notice it at the track.
But using particle brakes on the street made it show up.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
0.23060584068298 seconds processing time
