BIKELAND > FORUMS > ZX-14.com > Thread: Idle stall issue NEW TOPIC NEW POLL POST REPLY
Bluebyyou
Gettin My Curve On
posted March 21, 2009 03:16 AM
Idle stall issue
I recently tryed a new Muzzy map and later noticed an idle issue. When I fire the bike up it runs fine on the the fast idle circuit then after partial warm up idles way down to 6-700 rpm and kinda lopes then after complete warm up idle speed comes back up to normal 1 to 1.1 K. Sometimes it will sputter and die when it idles way down but restart immediately and not reoccur. The simple solution I suppose is to go back to the previous map. Whats the deal, bad map?
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
BobC
posted March 21, 2009 03:36 AM
Maybe thePC "throttle closed" setting was done with the engine cold, still on fast idle. That would do it.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Bluebyyou
Gettin My Curve On
posted March 21, 2009 05:54 AM
Hmmmm no thats not it, I always heat her up good before setting the T/P.
Ninja14
posted March 21, 2009 08:04 AM
All you did was change the map?
Flies out?
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
Bluebyyou
Gettin My Curve On
posted March 21, 2009 08:52 AM
Flies out?
Yep thats all, and yes flies out.
FastestBusaAround
I eat Fish...
posted March 21, 2009 09:04 AM
Did you set the TPS in the PC software before the map download?
FYYFF!!!
0.44068503379822 seconds processing time
