BIKELAND > FORUMS > ZX-14.com > Thread: Ping Bill Eason ZX-14 Qustion NEW TOPIC NEW POLL POST REPLY
LAB3
posted March 20, 2009 10:12 AM
Bill on another thread you posted that most of the ZX-14 you have seen
had "Detonation Problems"
I do not take my 14 to the Drag Strip but I do run fast on the open hiways here
in Texas. See my signature for how my 14 is now and my advancer is at 4 degres like
Muzzy suggested. I always use Shell 93 or if on a trip 93 where ever I am, if I can.
How can you tell if a bike with bolt on's like mine has a detonation happening.??
Louis
Compton
posted March 20, 2009 10:13 AM
reading the plugs can tell you a lot.
b.w.
LAB3
posted March 20, 2009 10:29 AM
Have you pulled the plugs on a 14? The good old days when I had my then new 1983 CB1100F. We would do a WOT in high gear and chop throttle, pull in clutch and kill engine.
Pull over and pull plugs with mag glass and look at the white porcline and look for dark spots. We even " Indexed the plugs back then with a shim kit. Carb's no darn FI or sensors, ECU. I'm learning, you can teach a Old Racer a New Trick... you just have to ask
:-) I don't think pulling the plugs on the side of the road is safe on a 14....... :-) the price we pay to have a good aro package.
Louis (LA) Bartay
posted March 20, 2009 11:18 AM
When pulling away from a dead stop or a idle roll in 1st, 2nd or 3rd gear clutch out, twist it wide open, you will hear it ping if it is detonating.
An engine will almost always detonate worse under full load low rpm, than upper rpm.
I found the spring and fall the pump fuel with added butane for winter fuels is very susceptible to detonation, but never had issue in the summer.
Bill will chime in when he has time as well i am sure.
Bluebyyou
Gettin My Curve On
posted March 20, 2009 02:39 PM        Edited By: Bluebyyou on 20 Mar 2009 22:41
Lug it from a stop in second gear and pin it, if it's detonating you should hear the valves clatter. I have heard of guys who don't wring these things out on a regular basis having carbon build up causing this.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
gilberjj
Friend of Fast
posted March 20, 2009 03:03 PM
Well, I shouldn't have carbon deposit/build-up problems!!!!! haha
billeason
detonation
Louis
Looks to me like some very good info/feedback from the members here Lou! With the mods you have knock should not be a problem. I would still look for the best fuel you can find [pump] also i would set the rotor between the middle and first mark on it. This will get you roughly 2.1/2- 3 degrees advance. When i check the timing on the 14's running' each mark on muzzy's rotor is actually 5 degrees. Its like they guys are saying best way is to read the plugs' but i wouldn't worry about your tune. Most bikes that come thru here is leaned on pretty hard. The 14 does tend to detonate without much warning...................Bill
bill eason
LAB3
posted March 20, 2009 06:29 PM
Thanks to all. I will moved the advancer Bill, good to know about the advancer. I am at a mark and 1/2. Too much advance?
billeason
posted March 21, 2009 05:40 PM
Way to much unless you run race fuel. Set the rotor half way between the center mark and the first one next to it. This will give you 3 advance' your setting at about 8 degrees. I would not leave it there expecially in the heat of summer!.......................Bill
bill eason
LAB3
posted March 21, 2009 06:23 PM
I will move it before I ride again. I have only had the advancer on a short time and
not many miles, cold and raining. Damn the guy I got it from told me each mark was 2 degrees. Never again will I install anything that does not have the information with it.
Thanks Bill
Louis
billeason
posted March 21, 2009 07:26 PM
No problem lou . If you run into a situation again where you don't get the intructions or are not sure about something '' give me a shout. Hell i probably have info on disc or paper for most bolt ons and then some, LMK anytime i will try to help out. No longer then you had that timing advanced it didn't hurt anything i doubt ,just don't race on it ..........Bill
bill eason
0.24305200576782 seconds processing time
