BIKELAND > FORUMS > ZX-14.com > Thread: Steering Stabilizer NEW TOPIC NEW POLL POST REPLY
icarus
posted March 16, 2009 02:33 PM        Edited By: icarus on 16 Mar 2009 22:40
Steering Stabilizer
What are you using? How do you like it ? Price? Planning on going to Maxton in
Sep and/or Oct so I have to have one. Thanks
P.S Will it work with a strap. Thanks.
8.820 @ 161.05
masszx14
A mind beside itself!
posted March 16, 2009 03:44 PM
I have the GPR V4- used it last summer and fall with
no problems as leaks and such.
I'm not strapped, but I'm pretty sure it wouldn't be an issue.
Here's a bad pic of it on the bike:
universal@mind
MasterBlaster
posted March 16, 2009 04:04 PM
mine
icarus
posted March 16, 2009 04:52 PM
Mass, I may go with the GPR. If you can get a good pic from the side so I can see if the
strap will clear that would be great. Thanks.
8.820 @ 161.05
Red1
posted March 16, 2009 04:57 PM
GPR V4!
Red12/Blue14
masszx14
posted March 16, 2009 05:04 PM
Sorry... can't do. The bike is still in storage.
May be someone else will help with a better pic
universal@mind
slates
posted March 16, 2009 05:07 PM
I have GPR V4, but wouldn't work well with straps unless you do it over the bottom triple tree. If strapping, I'd use Brocks.
icarus
posted March 16, 2009 05:11 PM
Mass, no problem.
Slates, is there not enough room under the damper? Could different brackets be
fabricated to facilitate use of the strap. Thanks.
8.820 @ 161.05
slates
posted March 16, 2009 05:17 PM
where most straps come over the top part of the frame the mounting bracket has set screws that go on the top of that frame on each side of the front gas tank cover screw.
icarus
posted March 16, 2009 05:19 PM
OK. Thanks for the reply.
8.820 @ 161.05
posted March 16, 2009 05:20 PM        Edited By: Shane661 on 17 Mar 2009 01:21
On my 12R I was able run a strap with the Scott's damper...it has only about 1/2" to slide the strap through. Is the GPR tighter to the steering head than that?
posted March 16, 2009 05:23 PM
My Muzzy damper, with strap mounted:
Good quality, lots of pieces. I may be interested in trying another...
icarus
posted March 16, 2009 05:26 PM
Thanks for the pic.
8.820 @ 161.05
slates
posted March 16, 2009 05:29 PM
It's pretty tight, not much room, especially if you're doing slow turns.
0.41075682640076 seconds processing time
