BIKELAND > FORUMS > ZX-14.com > Thread: nitrous gear activated NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted March 14, 2009 08:48 PM
I have a PC3USB and dynojet quickshifter already on, and am waiting delivery of a dynotune 40 shot dry system and am trying to work out a safe way to use it. If I get a hub and ignition module I think I can run two maps with different ignition timing ,can I also program it as a window switch and wot switch and gear activation? If so do I get rid of the TRE (sorry guys) so proper gear signal is given?Flies are out already. I want it to activate the solenoid in my selected rev range only and not till second gear. I dont want to be pushing a button as my bike is better than my coordination and ability. Any sugestions as to the best and cheapest way to achieve this would be appreciated as my wife doesnt understand about the cash realities of setting up a bike!!! Help me bash those pesky busas !!! Doug Mackay Australia 07 frame recall failure/ strapped / black with extra black / pc / quickshifter shift launch light / fender eliminator / bmc / full yoshi trc carbon / fan override switch / liquid performance / flies out / lowering links and no liscence.
posted March 15, 2009 12:16 AM
im quite sure you can do everything listed but gear activation. i used a Schnitz RPM window switch to activate nitrous in 2nd on my bike
Douglas Home
posted March 15, 2009 01:46 AM
I now realise the zx14 gear position sensor output voltage decreases as you change up gears . this makes it not compatible with schnitz window switch tprs-002LV . I would like gear activation as well asRPM window , and WOT any ideas Im desperate??? Got to spend this money before the wife sobers up!!!
Cheyenne
posted March 15, 2009 03:11 AM        Edited By: Cheyenne on 15 Mar 2009 11:18
If I understand it correctly you will be able to activate the nos in second, at WOT and at a specific rpm with the HUB. The only thing the HUB wont do compared to the Window switch is that it will not shut the nos of at a selected rpm. Schnitz has a new controller that will do all of the above-Schnitz PNC-3000 Nitrous Controller.
I have quick shifter, HUB with Schnitz TPRS-002 window switch. It is setup for WOT and a window of 8000 rpm to 10700 rpm. It is best to get rid of the TRE for drags anyway it just slows you down.
06redzx14
posted March 15, 2009 07:15 AM
The outputs on the hub are not gear based only tp and rpm
pazx14rider
posted March 15, 2009 07:35 AM
Dynotune sells a RPM window switch/with gear indicator. It uses a count of wide open throttle through the TPS to count the number of gears instead of using a gear indicator sensor. So say you want it to spray at WOT in 3rd gear you set the windowswitch at 3
Cheyenne
posted March 15, 2009 10:20 AM
OOPS!! You are correct. I should not "post" so late at night. Luckily there is always someone watching to correct our errors
posted March 15, 2009 02:30 PM
a dyna shift counter may work too
Douglas Home
posted March 16, 2009 05:00 AM
Thanks for all the advice , Ive decided to go with a hub (so I can switch between two maps) and the dynotune window switch #711 whitch at US$129 gives me wot activation/rpm window and gear activation and its waterproof. It is a two stage switch so later on after internal mods on the motor I can use a bigger shot. Hope this helps anyone in the future . Doug Mackay Australia .
Douglas Home
posted March 17, 2009 03:06 PM
Just got delivery of my dynotune nitrous system , very sexy looking ! Their black bottle guage is small and blends in on a black bike well . Got to get on order from schnitz , then put it all together . When my mods are finished I will post some photos. So excited just had to tell. Only trouble is I cant ride for shit and now I have no excusses!!! Love my wife $2000 on parts in a week . Presume Id better cook, mow ,clean,wash and buy flowers because I want those BST rims next.
gilberjj
Friend of Fast
posted March 17, 2009 04:20 PM
I'm getting married in June....... my bike will have competition for sure.....
0.25042605400085 seconds processing time
