BIKELAND > FORUMS > ZX-14.com > Thread: ?easy way to stop the rubbing? NEW TOPIC NEW POLL POST REPLY
specialzx14
posted March 14, 2009 07:40 AM
hey is there not an easier way to stop the tire from rubbing the undertail, i dont want to have to buy an undertail i ride double alot so im worried about the oil plug, but i drag race alot and i just like the way it looks lowered all the way down any ideas
posted March 14, 2009 08:34 AM
When is it rubbing ?
jdzx14
posted March 14, 2009 10:54 AM
When he is launching, i am having the same problem.
2007 Black ZX-14
posted March 14, 2009 11:03 AM
move it up a notch on your rear lowering link or make some room. shane's build thread explored this area extensively.
posted March 14, 2009 11:47 AM
cheap way....Adams straight link rocker arm, will give your shock more leverage, prevents bottoming under load..
expensive way... have your shock shortened, revalved and respring
posted March 14, 2009 04:18 PM
How much is the adams straight link??? Since I put my extensions on I can't put it on the lowest hole, bc it bottoms out like some serious shit! But then on the middle hole its HIGH.... Wtf...
TooHype
Go Hard or Go Home !!
posted March 14, 2009 06:32 PM        Edited By: TooHype on 15 Mar 2009 02:34
Adams Performance Straight Link $198.00
http://www.orientexpress.com/Kawasaki/Sport/ZX+14+Ninja/Chassis/Lowering+Links/Adams+Performance+-+Suspension+Link+-+Kawasaki+-+ZX+14+ZZR+1400+Ninja+2006-2007%25252FCNC+Machined%25252FBillet+Aluminum%25252FStraight+Link%25252FNo+Knuckle.html
Free Image Hosting at www.ImageShack.us
QuickPost Quickpost this image to Myspace, Digg, Facebook, and others!
posted March 14, 2009 06:33 PM        Edited By: dubious on 15 Mar 2009 02:37
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4942958&showprevnext=1
$185
Schnitz sells em, not so much for height but leverage ratio changes so the bike won't waste as much energy squating compressing the spring off the line, unloading the tire on the shift, and altering the balance and traction....
way cheaper than a shock...
TooHype
posted March 14, 2009 06:35 PM
~$170 if I recall right.
+1
Bently
2012 14r In Blue and no Mods!
posted March 14, 2009 06:47 PM
Or just lose some weight! just kidding I have the same problem I orderd the tiger undertail yesterday.
posted March 14, 2009 10:33 PM
Set your rear shock .... Turn in the adjustors all the way in and back out a 1/4 turn ...Give that a try ...It works for me ..
posted March 15, 2009 04:04 AM
posted March 15, 2009 06:31 AM
I made a steel plate and put it right where the tire rubs ... Cheap and easy ...
posted March 15, 2009 08:01 AM
Is Eclipse a lightweight like Lee?
posted March 15, 2009 08:02 AM
Smokin did you rivet in place? If the tire hits that palte hard enough, won't that slow you down more than need be?
posted March 15, 2009 08:03 AM
Some pics of the plate would be great!!
Silver08
posted March 15, 2009 01:22 PM
also a note, with the Adams straight link, you will need to buy Adams lowering links, or some that are made to be used with the straight link (shorter)
08 ZX14
posted March 15, 2009 03:12 PM
I have been 1.34 60 foot with it rubbing ...It doesn't rub for long or that hard either ...I don't think it slows me down but i could be wrong .. I will take a picture of it and it post later ... The plate bolts in where your old mud flap was ... No drilling or pop rivets...
posted March 15, 2009 03:14 PM
Lee, how low is your bike in the rear?
posted March 15, 2009 03:22 PM
3 hole on Muzzy lowering links ( as far as i can go ) Maybe a picture will help ..
posted March 15, 2009 03:23 PM
Never had the fuel pump hit either?
posted March 15, 2009 03:25 PM        Edited By: smokinZX14 on 15 Mar 2009 23:26
Nope ... The undertail drain hole does leave a light mark on the swing arm but the pump is fine ..Don't forget i only weight 150 pounds .. With a 200 pound rider all bets are off ..
Bently
posted March 15, 2009 05:52 PM
Hey you calling us fat.LOL
posted March 15, 2009 06:40 PM
LOL sorry .....
Bawls
re-learning to ride
posted March 15, 2009 06:46 PM
hell bently you're hopeless... I'm 180-185 lbs and for a drag racer I'm fat lol
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
0.24668097496033 seconds processing time
