BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 Break in question NEW TOPIC NEW POLL POST REPLY
jrp0629
posted March 13, 2009 08:28 AM
I just picked up my new2007 14 on Saturday and my new Bruce Fab slip onexhaust is supposed to be here today. I want to put it on tonight but the bike has 0 miles and has not been broken in yet. Would it be safe to put the exhaust on before the break in is complete? What do you think?
Tool Man
posted March 13, 2009 08:51 AM        Edited By: Tool Man on 13 Mar 2009 18:46
This about covers it
If you want a dog....walk it
http://www.ntnoa.org/enginebreakin.htm
Also...buy a couple of oil filters, Change the oil @ 500 & 1500 mi. There are many machined sufaces that wear against each other in a motor.
During break-in they will rub and shear off. (This is normal) BUT... get them out of that motor. Then every 3,000 or @ recomended intervals
If you wait till 3,000 till the first one your motor will be swimming in them.
Oil changes are very easy on a 14, the filter from the factory can be a "little" tight though
The banks are failing..
The banks are failing...
Invest in Ammo
posted March 13, 2009 09:00 AM
I put my full exhaust on with less than 100 miles and its still runnin like a top after a few hundred passes at the track and 6500 miles
posted March 13, 2009 10:09 AM
+1
juicey69
slowpoke
posted March 13, 2009 10:18 AM
500/1500/3K
Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles ..." - Hunter S. Thompson
bruno nadeau
posted March 13, 2009 10:38 PM
mine (06)got 43000 miles on it slip on fly out pc3 after about 150 miles 0 problem
bruno nadeau
Old Guy
posted March 14, 2009 12:16 AM
Buy good filters !!!!!!
I used Napa 1358 (made by Wix)
There is others that are good/better, but I took apart a kawi filter. Never Bought another
i'll those who now suggest what oil to use.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Bently
2012 14r In Blue and no Mods!
posted March 14, 2009 05:14 AM
Put the slip-ons on it and go run it how you want. My first 14 was to the track before it hade 50 miles on it and the guy that bought it from me has 12000 on it now with no issues
INTIMIDA2OR
RED rider!
posted March 14, 2009 12:20 PM
Mine was run to the speed limiter when she was brand spanking new . Then i put on my exhaust
44,890 miles later nothing but smiles
'06 Passion Red ZX-14
*Lee*
Ninja14
posted March 14, 2009 03:22 PM
Mine was run to the speed limiter when she was brand spanking new ......
Now why do I have NO problem believing that :-)
...............I recommend no more stoppies though......the stock swingarm is kinda thin....
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
posted March 14, 2009 03:36 PM
2 heat cycles to wear in cam and crank brg surfaces, and set the castings and molecules of pistons and cylinders ,
then moderate to full throttle low to mid rpm roll ons...Load the rings so they wear in square
I did full throttle roll ons from 10 to 200 mile period, on an empty straight road.
At the end of 200 miles it was bounced off the speed limiter as well...
ala motoman...
As Gene said, the initial oil changes are critical, much more critical than any other ...
LAB3
posted March 14, 2009 07:07 PM
What are some of the other brands that are good quality?
TooHype
Go Hard or Go Home !!
posted March 14, 2009 10:06 PM
I have been using the Fram PH6017A filter lately. Any coments ?
posted March 15, 2009 04:40 AM
oem oil filter here
Bently
posted March 15, 2009 05:20 AM
OEM filter here to.
mokaw
posted March 15, 2009 07:48 AM
I used to work in an Auto Parts store. They had cutaways of a lot of oil filters and the Fram had the least paper inside, so I would say it has the least filtering capability, too. One of the best was Wix.
Every knee shall bow, every tongue confess that Jesus is Lord!
Red1
posted March 15, 2009 11:38 AM
Two of the best filters around (IMHO):
Purolator Pure One 14610(L) 14612(s)
Mobil M1-108
Red12/Blue14
LAB3
posted March 15, 2009 07:56 PM
K&N oil filter has a 17mm hex nut that is drilled for safety wire. KN-303 or if you have
to have Bling KN303C.....chrome plated. The Mazda V6 has the same filter as the ZX-14.
0.32975912094116 seconds processing time
