hardatit
posted March 10, 2009 04:27 AM
fan switch
Has anyone put a switch on the fan where you can manually turn it on. I would like to still have it kick on by itself but have the ability to turn it on manually, like when turning the bike off so it can stay on longer or in between runs. If anyone has done it and can tell me what wires you hooked into to switch it on it would be a great help.
Halvefast
posted March 10, 2009 05:40 AM
Here is a how to from Wheelie:
http://www.zx14.net/publicforum/index.php?topic=578.0
ECTA Ohio Mile 195.132mph
KawaBonzai
Leader of the Back.
posted March 10, 2009 06:48 AM
quote: The topic or board you are looking for appears to be either missing or off limits to you.
Please login below or register an account with ZX14.NET "Enhancing the ownership of your Kawasaki ZX-14" .
Sigh
Halvefast
posted March 10, 2009 07:41 AM
You will not have hazard lights with this modification, the hazard button will be your fan switch.
Remove left upper cockpit panel. Remove the two screws that connect the left handlebar control.
Photo 1 Cut the zip tie holding the cluster of wires that is "inside" of the left handlebar control, cut the Orange wire and the Green wire to the hazard switch button. I also cut the Gray wire, (not to be connected).
Photo 2 Run two wires through the shrink tubing, these two wires you slide through will connect to the Orange and Green wires, make sure you have enough wire at the other end of the shrink tubing so you can route to the proper connection, carefully soldier them together, and tape well.
Photo 3 Replace the zip tie, make sure you mark one wire to the Orange, that will be the hotwire, the other will go to the fan connection plug.
Photo 4 Route the wire connected to the Green to the fan connection, I slid the Green wire into the Blue wire, it should fit tight, tape well.
Photo 5 Locate the harness plug that is wide, its behind the left headlight area.
Photo 6 Run the Orange wire into the large White wire connector, make sure it fits tight, tape well, install your panels, your hazard button is now your on/off fan switch, if you see you are going to be stopped for a few minutes in traffic or a long redlight, simply press the hazard button and your fan starts cooling your engine without having to wait until the engine gets hot and comes on automatically, it will still work automatically if you forget to press your hazard button, the fan switch will work without the engine running, Drag Racers will enjoy this feature as well.
Forgot about that, I can't get the pics, but maybe you can ping wheelie for a set.
Wheelie
Old Man
posted March 10, 2009 04:18 PM
quote: You will not have hazard lights with this modification, the hazard button will be your fan switch.
lmk
wee
hardatit
posted March 10, 2009 04:25 PM
I do appreciate the direction, going to try it out tommorrow.
Wheelie
Old Man
posted March 10, 2009 04:33 PM
I think I lost the copyright to the photos. lol
wee
gilberjj
Friend of Fast
posted March 10, 2009 04:54 PM
quote: I think I lost the copyright to the photos. lol
wee
HAHAHA. they belong to me now!
LAB3
posted March 10, 2009 05:45 PM
wee
I just right clicked and opened each pic one at a time. Good Idea but I was thinking of a seperate toggle switch. As I am installing a second fan from HPC and want it to turn off and on manual. Good job wee.
Ninja_Knight
posted March 10, 2009 08:16 PM
quote: I just right clicked and opened each pic one at a time. Good Idea but I was thinking of a seperate toggle switch. As I am installing a second fan from HPC and want it to turn off and on manual. .
PMR switches. Even the dual buttons look neat and clean.
LAB3
posted March 11, 2009 04:46 AM
Thanks, I will Google PMR and look for the switch.
Ninja_Knight
posted March 11, 2009 05:50 AM
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4967063&showprevnext=1
I couldn't find one installed on a 14 but I will show you pictures of mine once I get it done. I've just been too busy lately.
LAB3
posted March 11, 2009 10:43 AM
Thanks..... I was looking at a single PMR. I have the LSL Bar Mount Kit so I have old school handle bars. Looks like I can find a good place and clamp on.
Ninja_Knight
posted March 11, 2009 02:50 PM
Only reason I am doing the dual switch is because down the road I intend to install some leds and some Gator Glass.
Old Guy
posted March 11, 2009 09:35 PM
Water proof switch w/plastic bracket mounted with windscreen wellnut.
Power is from a terminal strip I ziptied to ram tube to a splice on fan side of factory plug.
The fans plug to the wiring harness is just above the coolant tank.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
