BIKELAND > FORUMS > ZX-14.com > Thread: How low can she go... NEW TOPIC NEW POLL POST REPLY
KSPZ3
posted March 09, 2009 01:11 PM
I need some thoughts here. I had my pan cut down to move the drain plug and increase the ground clearance about an inch in total. Now of course the header pipes are low point. I have back dog bones on the middle and the forks up about an inch in the triple trees. I have the blocks that can be put into the forks that would elliminate abour 1.35 inch of travel - this would allow me to move the forks up another 1". Now assuming I put the Tiger Tail in - I am still concerned thaat the bottom may ground out - Is there a way to reduce the back shock travel - without buying a new shock? also - anyone have experience with this type of set-up withourt reducing the rear shock travel? I am at stock wheelbase.
Thanks for the input.
Kevin
pazx14rider
posted March 09, 2009 02:51 PM
maybe a spanner wrench and tighten the rear spring up but i dont know how the ride would be as a result.
posted March 09, 2009 03:15 PM
you can tighten the spring you got some or get a stiffer spring, when you order there are guidelines for weight and setup for your situation
0.26349401473999 seconds processing time
