BIKELAND > FORUMS > ZX-14.com > Thread: Hey Dubious I got a question???? NEW TOPIC NEW POLL POST REPLY
jdzx14
posted March 04, 2009 05:21 AM
I seen on a post somewhere that you used your dynotune nitrous setup for your air shifter bottle and mount, i have the same setup, but am installing a bigger bottle, so i want to use my Dynotune kit for the air shifter, my ? is how did you do the plumbing from the peg bracket and what all do i have to do to accomplish this task? THanks, would have pm'd you but its not working still.
2007 Black ZX-14
posted March 04, 2009 07:27 AM        Edited By: dubious on 4 Mar 2009 15:28
I used a muzzy system with dynotune bottles.
Any air shifter will work, but if its a low pressure system you will also need a High pressure regulator.
Schnitz sells em.
I ran the hoses directly throught the undertail, ran the left over to the right side, a T to tie the bottles together, then a second T, one side for the N2O shot solenoid, the other side fed the HP regulator which supplied 150 psi N20 to the shifter solenoid and then the ram.
I was going to post all the pics under the tank and seat as well but can't find them
jdzx14
posted March 04, 2009 05:21 PM
Thanks Dubious, i am only using one bottle on the right side, but same setup, i am using a MPS kit with no bottle. I plan on running one line from the bracket to the compressor and the other to the shift solenoid and a T for the gauge, will have any problems with that?
2007 Black ZX-14
posted March 04, 2009 10:00 PM        Edited By: dubious on 5 Mar 2009 06:14
Am I missing something.
Are you running a nitrous, and an air shifter?
What are you using for an air resevoir?
If you are not running nitrous your system makes good sense.
I am running my compressor to a T from the swingarm resevoir that also is plumbed to the solenoid for the shifter... I am also using an MPS switch with an inline manual power switch so the compressor can be set ro run aotomatically, or can be controlled manually as well.
jdzx14
posted March 05, 2009 05:27 AM
Ok i am just running air, i have a seperate nitrous setup. Thanks.
2007 Black ZX-14
0.23587989807129 seconds processing time
