BIKELAND > FORUMS > ZX-14.com > Thread: horn wire? NEW TOPIC NEW POLL POST REPLY
specialzx14
posted February 28, 2009 04:28 PM
horn wire?
trying to hook air shifter to horn button what wire can i use off of the button i need the one that will activate the air shifter stuff
posted February 28, 2009 04:37 PM
I took mine off the horn itself, just unplugged it and added a connector to fit it.
specialzx14
posted February 28, 2009 05:02 PM
got it thank you!
specialzx14
posted February 28, 2009 05:23 PM
nevermind i dont have this is really pissing me off
posted February 28, 2009 05:36 PM
You should run the power from the shifter up to where the horn is, and I can't remember which side it was but unplugg it, and put a connector onto the wire from the shifter and plug em up
specialzx14
posted February 28, 2009 05:39 PM
im hooking the horn button up to a toggle switch that goes to the shifter stuff i tested both wires one is a constant power the other i cant get to do anything not even when i hit the horn button
posted February 28, 2009 05:53 PM
I understand the frustration! I didn't actually hook mine up, I watched. So when it comes to that I can't help much, but be patient, someone here can give you better advice than me
specialzx14
posted February 28, 2009 05:59 PM
maybe cause i just hooked that wire to the shifter smoke came out of the horn button its burnt up now
kawasakijockey
posted February 28, 2009 06:06 PM
The horn wire that does not do anything is the horn ground from the horn button. Run that wire to the common "C" or "com" on the toggle switch. run another wire from one of your other terminals of the tog. switch to the horn and the other tog sw. terminal to the airshift stuff. All this means is your horn activation is ground wires instead of 12v hot.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
specialzx14
posted February 28, 2009 06:14 PM
thanks but now i have to replace the horn stuff on the handle bars know where i can get it cheap
posted February 28, 2009 06:21 PM
Why u replacing that stuff??
specialzx14
posted February 28, 2009 06:26 PM
the horn button is not workin when i hooked the wires up to it smoke came out of the horn button
ninja12
posted February 28, 2009 07:37 PM
Some people have their bike mixed or are just guessing.
You can't hook the hot side to anything. use a test light to figure which is hot.
The ground side only goes ground when you push the button. (this is your wire)
I think the key has to be on.
You can test your horn assembly by hooking your horn back up with no other wires attached to it anywhere and blow your horn. If that works................................................................
Run a FUSED 12v wire (battery or fuse box) to one side of the shifter, and the horn ground wire to the other.
Turn key on and hit the horn. test with no air pressure you will hear it click when you hit the button. What kill box are you using?
Sorry you can't use the + from the horn because it's always hot reguardleess of button push.
ninja12
posted February 28, 2009 07:44 PM
once you get that to work
you can put a shifter/horn switch in the ground wire.
1. run one wire from the horn ground wire to the center of the switch,
2. one side of the switch goes to the horn
3. the other side goes to the shifter.
You can leave the 12v + side on the horn as it is not used.
specialzx14
posted February 28, 2009 07:46 PM
im using my powercommander as my kill box i fixed the horn some copper colored wire fell out stuck it back behind the button and works for now the diagram i found on here for using the powercommander uses a 6 pole toggle swith i cant even find one around here
ninja12
posted March 01, 2009 06:42 AM
no diagram needed.
once you get the shifter wired,
get the quick shifter software , and load it into your powercommander.
then use the same ground wire (horn) put another wire "T" to the pc.
enjoy.
specialzx14
posted March 01, 2009 10:41 AM
thank you last night i had it workin almost the horn button made the relays click but there is a copper piece in the horn that makes contact and activates that piece is f up so i have to find that piece or buy a whole left switch
posted March 01, 2009 11:00 AM
Damn man that sucks...
ninja12
posted March 01, 2009 08:29 PM
I'll bet someone has a horn assembly here or ebay.
specialzx14
posted March 01, 2009 09:02 PM
i just need the horn button itself i dont see spending 50 bucks for the whole thing
0.34165692329407 seconds processing time
