BIKELAND > FORUMS > ZX-14.com > Thread: How does turbo effect bottom end? NEW TOPIC NEW POLL POST REPLY
Rook
posted February 24, 2009 09:07 PM        Edited By: Rook on 25 Feb 2009 05:24
I know it doesn't add any power until the engine revs high enough. However, there is no stock exhaust at all with a turbo. How does the turbo header and pipe(s) compare to your average aftermarket 4-2-1 full system for bottom end?
^^^You know, most aftermarket pipes loose a little on the bottom end.
Rook
kaw now
posted February 24, 2009 11:31 PM
Don't have a turbo but have read that same rules apply for header design turbo or no. Obviously not enough room to put a full header on a bike with a turbo. Does it matter not really. I used to have a 750 turbo and found that when cruising say up a hill even at lower rpms when the engine is loaded the turbo starts to boost and creates plenty of torque. Its like having extra automatic gearing don't have to downshift or hardly open the throttle.
gilberjj
Friend of Fast
posted February 25, 2009 12:37 AM
If you have the bike tuned correctly, and you are using stock motor (12:1) compression, you shouldn't have any real noticeable loss in low end. Turbo cars and bikes are known for having soft low ends because they generally use low compression so they can have more boost on pump gas. All out race engines use a fuel that allows for high compression AND high boost. But you need fuel like c16, q16, vp import, methonal, and nitromethane to name a few.
zxbob
posted February 25, 2009 04:30 AM
Rook ...
My bike runs just like a ZX-14 ~ untill it does'nt !
Bob ..
Ninja14
posted February 25, 2009 08:36 AM
Felt to me that it was choked just a very little bit at low RPMs - I'm talking about parking lot speeds basically.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
1badzx12r
posted February 25, 2009 09:27 AM
Rook ...
Bob ..
just like you except mine builds boost @ 2k rpm even tho its only 1lb its more than a stocker has at that rpm ....my power band is to smooth
NINJA12
posted February 25, 2009 09:55 AM
1bad you stock compression or lowered?
1badzx12r
posted February 25, 2009 10:55 AM        Edited By: 1badzx12r on 25 Feb 2009 22:47
stock ...i'm got a bone stock motor thats never been open except 4 washers behind clutch springs ...and i little turbo cycle logic kit ...set @7lbs street... but at track running 11lbs this last weekend on last pass before track closed
I have not been able to make a perfect pass yet ...fighting wheel spin and wheelies the 1st half ..
but with 300lbs rider and a 1.60 ft 9.20's @150ish mph ...
davej
posted February 25, 2009 11:26 AM
Actually the bottom end came alive compared to a stock ZX-14. Part of the Muzzy stage 1 was to remove the flies that may be some of the reason for all that low end power. At 3000k it starts to pull smooth, fast, and hard, no 2 stroke power bad just zooms. 15,500 miles on the turbo now with no problems.
Triumph guy
posted February 25, 2009 02:02 PM
What kind of numbers ( ET MPH ) you getting at 11 psi ?
NINJA12
posted February 25, 2009 02:37 PM
11 psi with c16?
1badzx12r
posted February 25, 2009 02:42 PM
11 psi with c16?
nope AVGAS
1badzx12r
posted February 25, 2009 02:52 PM
trash pass ...wheelie and wheel spin killed it ...9.40@150 ..300lb rider.. you know 2 of you and then some ..
i can't get it all down to the track even my size @7lbs ...and if i do hook then its a stand-up wheelie in 1st and 2nd gear ...
1badzx12r
posted February 25, 2009 02:54 PM
but i fit into the 9.50 index perfect even if i spin
Rook
posted February 25, 2009 07:28 PM
Interesting that some setups seem to start boost a little right above idle.
I can see this is another venture frought with questions, decisions and performance trade offs. I know I'm going to have alot more questions once I start learning more about these systems.
Thanks for input, everyone.
Rook
duncan
posted February 25, 2009 07:34 PM
Do you have a boost controller? If so ramp it some.
posted February 25, 2009 10:06 PM
that mph seems low for 7psi on a 14? i ran several 147s and a 148 on my 12r in 07, just a muzzy pipe, pc3r and k&ns on pump gas. 190lb driver. what are other boosted 14s trapping? my buddy has a turbo 10r( 05 stock motor) and runs 155 on 6psi on pump gas his tuck sucks and hes my size
posted February 26, 2009 06:30 AM        Edited By: smokinZX14 on 26 Feb 2009 14:31
300 pound rider and stock wheel base , i would say 150 MPH was pretty damn good .. I have seen his bike and it's not lowered ..It does get lower when he sets his 300 pounds on it ...lol..
1badzx12r
posted February 26, 2009 08:02 AM        Edited By: 1badzx12r on 26 Feb 2009 16:04
no boost controller ...
1badzx12r
posted February 26, 2009 08:06 AM        Edited By: 1badzx12r on 26 Feb 2009 18:41
the bikes done 165mph with a 2.40 60ft and a 150lb rider with tire spinning mid track on 7lbs ... and the rider being cautious(short shifting) to ring it out being it wasn't his bike...i never said it was its best mph just what i did that pass .. ..
there were several turbo busa running that day with 10lbs + of boost with riders around 200lbs trapping 150-156mph so with my 300lb ass i don't think i and bike was doing bad
http://psychobike.com/forums/gulf-coast-racing/12196-some-pics-hrp-sunday-2-22-09-a.html
1badzx12r
posted February 26, 2009 08:17 AM        Edited By: 1badzx12r on 26 Feb 2009 16:19
the black and red 08 has farley hall riding and had run 8.90's at 155mph on a stock wheel base bike ,stock OEM MOTOR bike ... may have even been faster but i don't know ...he runs in the super sport class ...
There WAS A BRAND NEW BONE STOCK 09 GREEN BEING PILOTED BY HIM BUT I DIDN'T SEE A TIME ON IT...
posted February 26, 2009 03:21 PM
ah yeah, 165 is more what i was expecting seeing how stock motors can run 150+
posted February 26, 2009 04:42 PM
" stock OEM MOTOR bike " Sorry it's not stock , fact is pretty far from stock ..But it does follow the SS rules ..
posted February 26, 2009 04:51 PM        Edited By: smokinZX14 on 27 Feb 2009 00:54
Here is 1bad in action ...He make a zx14 look small ...
1badzx12r
posted February 26, 2009 05:28 PM
thanks smokin for me pic..i know we'll never agree on the Stock OEM super sport bikes... but in the rules you can only use stock OEM parts
and when somebody like shine wins his bike is broken down and inspected by AMA..
its amazing what hp is coming from a surface job and OEM parts AND blue print install of parts..
exhaust can be whatever and powercommanders ...but that motor is OEM PARTS which is the same parts in my bike and yours but some really smart motor guru put it together
0.24045395851135 seconds processing time
