BIKELAND > FORUMS > ZX-14.com > Thread: lock up clutch NEW TOPIC NEW POLL POST REPLY
750 turbo
posted February 21, 2009 12:36 PM
lock up clutch
What is the best lock up for the 14? Any one using Cycle Logic system?
ninjaboy311
posted February 21, 2009 02:16 PM
Yes, it is a great piece and a great price. Streetable too.
I'm at 500 passes on clutches right now using it.
Bad in Black
posted February 21, 2009 02:44 PM
I have one I'll be installing shortly........I've heard nothing but good about them, and I've never come across a better guy to deal with than Dave, the owner of Cycle-Logic
posted February 22, 2009 05:03 AM
How much are they selling for?
ninjaboy311
posted February 22, 2009 05:18 AM
Best deal I've seen is to get it from Cycle Logics on their ebay store..
http://cgi.ebay.com/ebaymotors/Kaw-ZX-14-zx14-zx-14r-zx-14-r-Lock-up-clutch-loc-up-kit_W0QQcmdZViewItemQQitemZ150290989940QQptZMotorcyclesQ5fPartsQ5fAccessories
posted February 22, 2009 05:21 AM
What benefit are you seeing from the lock up? Any more mph compared to standard springs, when on motor?
ninjaboy311
posted February 22, 2009 09:15 AM
For me, being an every weekend bracket racer, my #1 reason was for extended clutch life (500 passes on this set). Second reason was for the consistency it offers (most runs on any given night are often within thousandths of each other). 1-2 MPH extra on the top-end was just an added bonus.
mokaw
posted February 22, 2009 09:23 AM
I've been thinking about getting one, but I'm not too familiar with how you launch with one installed. About what rpm do you launch at and do you have to slip the clutch or does the lock up do it for you? Bolt on and no adjustments?
Or would I be better off to use Brock's springs and spacers?
Every knee shall bow, every tongue confess that Jesus is Lord!
kawasakijockey
posted February 22, 2009 11:16 AM        Edited By: kawasakijockey on 22 Feb 2009 19:17
You can launch the CL at any rpm since it is a single stage. It is bolt on, no adj. The thing with a lockup is the engine spinning any rpm will not make it lockup. It is the input shaft to the tranny that the clutch hat is on that locks it up. As long as you have the lever in you can spin it to the rev limiter with no problem, but when you let the lever out and the clutch hat speed picks up to about 8000 rpm the lockup is in force.
There are different reasons for using a lockup and the lightweight riders would probably not see much benefit if they use hd springs and spacers.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted February 22, 2009 11:20 AM
Is it accurate to say that by adding weight you effectively lower the rpm at which a single stage locks up?
I think it is possible to tune a single stage on some bikes. We have a Busa that the prior owner tuned to just throw the lever at 6500 rpm, stock wheelbase.
kawasakijockey
posted February 22, 2009 11:32 AM
Yes adding weight to the arms lowers the lockup speed but at the same time increases the lockup pressure on the clutches too at higher rpm. The Cycle Logic kit does not come with any adj. features but it could be done easily I bet.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted February 22, 2009 11:35 AM        Edited By: Shane661 on 22 Feb 2009 19:40
You mean you can't add or remove weight??
Like on our Busa MTC setup you add/subtract weight from the arms and change and/or shim the springs...
mokaw
posted February 22, 2009 11:38 AM
Thanks for the information kawasakijockey. Since I'm a lightweight, I don't think I'll opt for the HD springs and spacers. I think I'll get myself a cycle logic lockup.
kawasakijockey
posted February 22, 2009 11:42 AM
No springs on the CL, just weight. The bolts arent long enough to add anymore weight as it comes and the weight is a collar instead of shims.
Should have stated also that high horsepower will drive through the stock clutches and at that point it is absolutely necessary to have a lockup.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted February 22, 2009 11:45 AM        Edited By: Shane661 on 22 Feb 2009 19:47
The springs aren't on the lock up, persay...they go where your standard springs go....you just vary the strength or shim them to add preload.
So, when you change your springs you are changing your static pressure. And then by altering the weights (if so equipped), you are changing how quickly the lockup goes to work.
Anyway, that is my basic understanding. And again, that is for the MTC we have on the Busa.
In the case of what you are describing, you could run stock springs for easy control and then let the lock up hold the power up top....but that is all I see it being useful for.
kawasakijockey
posted February 22, 2009 12:02 PM
Exactly Shane. And you last sentence is the very reason I have one.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted February 22, 2009 12:08 PM
I may also go that route. I already have the quick access cover installed. It would probably work well for the nitrous I am adding.
On the other hand, I thought of just running the heavy springs. I have big hands and the control isn't that bad...but definitely had some wheelie problems when I tried the heavy springs last year. And then burnt my clutch up from dragging the clutch to avoid them..
FIFTH
The Magnificent Bastard
posted February 22, 2009 02:46 PM
I installed the CL lockup to keep from burning up my clutches as my phat ass tends to put a little drag on the bike (clutches) on the top end. With just a clutch change (to included HD springs) and lockup addition, I gained alot of pull on my top end.
The CL lock-up is nicely made and simple to install. If anyone is thinking about get a lock-up clutch, I recommend this one, as I have about 3000 miles on mine and am absolutely happy with it. Seems like I got it off of ebay for $250-ish.....
BLK ICE
posted February 24, 2009 11:55 PM
Odered CL lockup kit today($284.85) . Should be here Thrusday.
Is there a down side (or up side) to clutch life running HD springs vs stock springs with CL lockup?
(I'm 280lb suited )
64" wb
16/44 gear
launching @ 3500 rpm off clutch and at full throttle before or at the tree.
footshifting
posted February 25, 2009 05:09 AM
I'm on my phone, so its hard for me to view these links, but whenpurchasing the lockup clutch does it come with new fibers/steels?
kawasakijockey
posted February 25, 2009 06:02 AM
No fibers or steels.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
SteddyTeddy
posted February 25, 2009 07:23 AM
I'm currently trying to setup a single stage lockup on my ZRX so I can just thow the lever and hold it wide open. You would be surprised just how little weight it takes for the lockup to work.
FIFTH
posted February 25, 2009 09:32 AM
(I'm 280lb suited )
64" wb
16/44 gear
footshifting
I am strectched, 16/43 gearing, 350lbs, footshifting.....before the lockup, I ran it up to 5k and went WOT while dumping the clutch. As long as the tire was hot, it hooked like all get-up. I have to lower my rpms to launch so I don't break the back tire loose. The lockup with HD springs definitely has a shorter clutch pull/release, but overall, I very much like the addition.
BLK ICE
posted February 25, 2009 09:43 AM
Thanks for the feedback. FIFTH.
posted February 25, 2009 09:47 AM
Off topic, but saw where you wanted to regear to 18/49. Why go up in the front then go up in the rear as well? I'm sure I'm missing something there, just was curious
0.23102688789368 seconds processing time
