JDC
posted February 15, 2009 05:19 PM
14 eletrical supply
I am about to put on an oil scqvange pump for the turbo setup I have. System as it stands can marginally get along without it... but it is right on the edge of the blade since the new exhaust went on and the oil return line needed to be re-routed.
The power requirements of the pump are 2 AMP's no load, and max 5 AMPs, wiht what I was told about 3 AMP running. Anyone have an idea if the 14's ele system/generating sys can handle this ok...
or would I need to beef up the ele charging sys a bit. And if so, where to get that./how to get that done?
Thanks.
Beondwacko
posted February 15, 2009 06:21 PM
3 amps is not all that much current. the high beams alone pull over 8 amps. You should be more than fine.
JDC
posted February 15, 2009 10:14 PM
Great, thank you!
