BIKELAND > FORUMS > ZX-14.com > Thread: Need help! NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted February 07, 2009 02:21 PM
Need help!
I just hooked up a msd shift light its got a GMR pickup that has to be hooked to the +12v coil trigger #4. The shift light is works when the bike is started but when rpm is set on shift light at say 2500 rpm it does not illuminate when rpm is reached. I checked for voltage on coil #4, both wires going into coil have 12 volts (with a test light). I have tried hooking the pickup to both coil wires individually on cly #4 and still nothing. I also loop the wire through the GMR like stated in the diagram. What am i doing wrong??
Ninja14
posted February 07, 2009 03:32 PM
Use the wire from the ECU as the trigger.............I'll have to look up the color again. We used this wire on the dyno - found it by backprobing.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
Ninja14
posted February 07, 2009 03:35 PM
I'm thinking it is the blue/white, but maybe someone can verify. I don't have access to the bike right now.
2006 Turbo ZX-14.
pazx14rider
posted February 08, 2009 04:49 AM
ok...anyone else possibly know the wire?
pazx14rider
posted February 08, 2009 01:56 PM
Figured it out have to go with the wt/bl wire off of coil #1 looped in pickup directions are wrong they are showing coil #4
pazx14rider
posted February 08, 2009 01:57 PM
sorry wt/rd and owe Bawls a big thank you for the service manual it was a big help Thanks man!
0.26662993431091 seconds processing time
